Error reading failed
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Kumpeldienst
Post07-06-2007, 22:28    Subject: Error reading failed Quote
Hello, I have a 1995 Volkswagen Golf Variant with a 75 HP diesel engine, and it's broken. Well, sometimes it works.
Sometimes (almost always), my preheating light blinks, and then the engine doesn't start.
After several attempts and a few taps, the light no longer blinks. Then, it starts working.
I know - reading error codes, but that's exactly my problem, the PC doesn't recognize it.
golf, as you know, sometimes the problem can be a faulty connector, or it could be something else.
Where is the motor computer located? I've been to many workshops, but none of them could read the data from it.
What a mess. Does anyone have any advice?
Thank you, Matti.
Kumpeldienst
Post07-06-2007, 22:32    Subject: Error reading failed Quote
ps: I don't have a 109 in the vehicle, is that normal? Or did someone just remove it at some point?
"Is it a different type of connector? However, the contacts look the same from the bottom as they do on the 109 model."
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9, MJ 98/99, Motor geht aus, Fehlercode 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts The pre-heating lamp is not turning off. Motor does not s... Diesel Engine Technology
No new posts Temperaturanzeige MFA geht nicht Diesel Engine Technology
