Reset Car Radio Code: How to Fix It
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-02-2010, 10:17    Subject: Reset Car Radio Code: How to Fix It Quote
Radio Alpha, Golf 3.
After replacing the battery, the CODE appeared, and then I pressed TA and TP simultaneously, as usual.
"The number '1000' appears, but it's not possible to input it using the 1st, 3rd, and 4th buttons; however, it is possible using the 2nd button."
Is the radio broken? It was working before.
Can I bet 1000 in a different way?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 27-10-2026, 6:10.
michiglaser
2007 Audi A4 Avant
Post13-02-2010, 13:22    Subject: Reset Car Radio Code: How to Fix It Quote
Even though it doesn't really help with solving the problem, Alpha and Beta radios sometimes go for just one euro at the 3-2-1 auction house.
I wouldn't waste much time worrying about that...
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Post13-02-2010, 15:34    Subject: Radio Code Reset: Unlock or Change Your Code Quote
teileklaus wrote:
Is the radio junk?
EEPROM or/and keyboard failure... This was a common problem with the Alphas.
He had already left.
Yesterday, the grandmother was still alive, today... [censored]... icon_eek.gif
Can I bet differently on 1000?
No, the code for VW car radios always depends on the serial number and is calculated accordingly.
Translated on 27-10-2026, 6:11.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-02-2010, 15:52    Subject: Reset Car Radio Code: How to Fix It Quote
Thank you, Bertil. I've tried experimenting with two input buttons, and they allowed me to switch through one or two digits, but not all of them. It's only a single attempt saved, so it should be possible. My suspicion that the EEPROM is the issue seems plausible, because "back in the day," icon_lol.gif it was possible to switch between different stations using station buttons.
I also tried using VDCS before, but I couldn't connect - although that might be intentional when the "CODE" message appears.
Translated on 27-10-2026, 6:13.
haithamina
Post13-02-2010, 16:44    Subject: Reset Car Radio Code: How to Fix It Quote
@teileklausViewing profile: teileklaus
I have a beta version from a 3BG Highline lying around, but the effort required to use it is too much for me.
haithamina
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-02-2010, 16:57    Subject: Reset Car Radio Code: How to Fix It Quote
"Thank you, I've already ordered one."
Ha, now the radio prices are dropping with each new offer icon_lol.gif.
Translated on 27-10-2026, 6:14.
Post14-02-2010, 10:01    Subject: Reset Car Radio Code: How to Fix It Quote
If your order doesn't go through, I also have an Alpha amplifier from a Volkswagen Golf 3, including the code.
Would you be interested in having it shipped for a small fee (e.g., €3.90 via Hermes)?
Sure. Here is the translation of the text from German to English:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used as a verb, meaning "to gust" or "to blow."
Post14-02-2010, 10:34    Subject: Reset Car Radio Code: How to Fix It Quote
Oops...
I still have an alpha version of a Polo 86c here, which still runs in my garage. It's from the pre-code era icon_smile.gif. It has a button and a mini display, it's quite bright... I could have parted with it otherwise icon_smile.gif.
Translated on 27-10-2026, 6:15.
Wiesel
Post14-02-2010, 15:51    Subject: Reset Car Radio Code: How to Fix It Quote
I could also, if necessary, still have an alpha and a beta from a G3 lying around icon_cool.gif.
Translated on 27-10-2026, 6:16.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post14-02-2010, 16:20    Subject: Reset Car Radio Code: How to Fix It Quote
Okay, thank you, thank you. I see, I'm probably stating the obvious. I might come back to this topic later. But I think it will work out with the order.
Post14-02-2010, 16:21    Subject: Reset Car Radio Code: How to Fix It Quote
teileklaus wrote:
I hope it works out with the order
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Task: Target Passat GTE - J743 and lift CP On-Board Diagnostics (OBD)
No new posts AFB Injector Timing: Adjustment Guide On-Board Diagnostics (OBD)
No new posts Adjusting the power steering assist? Transmission, Chassis, Body & Interior
No new posts TDI 1Z: Adjust Injection Timing by Removing Injector Pump Diesel Engine Technology
