Hood Compressor Torn: How to Fix/Repair?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
luiggi
Post18-04-2008, 21:31    Subject: Hood Compressor Torn: How to Fix/Repair? Quote
I'm having a problem: I have a compressor with a plastic motor cover. Unfortunately, this part has a crack about 30cm long in the cover. The plastic is about 5-8mm thick. Since the compressor is only 3 months old, I would like to inquire here if anyone has experience with such repairs? Perhaps gluing it, but with what? And how can I make sure it holds? Also, this cover is made of yellow plastic, so after the repair, you shouldn't be able to see much of the fix. Please give me your advice on how best to proceed and which materials to use. Thanks.
Translated on 19-08-2026, 13:04.
BM
Avatar-BM
Post18-04-2008, 22:34    Subject: Hood Compressor Torn: How to Fix/Repair? Quote
Maybe it sticks, but with what? Something that will actually hold? Also, this hood is made of yellow plastic.
To determine that, we would need to know what type of plastic it is.
If the material is PVC, it might be possible to use a solvent-based adhesive.
This is used, for example, for welding drain pipes (in the sanitary area).
Take a look at this:
http://solutions.3m.com/wps/portal/3M/de_DE/Industrial-Adhesives-and-Tapes/IATD/Products-and-Services/Products-and-Applications/Bonding-with-Adhesives/?PC_7_RJH9U5230GE3E02LECIE20OFU2_assetId=1114283823954
or here:
http://solutions.3m.com/wps/portal/3M/de_DE/3M-Automotive-Aftermarket/Home/-/Product-Catalogue/?PC_7_RJH9U5230GE3E02LECIE20O0H3_nid=6S97KX4457be87NJMWT6K3gl
3B5 AJM
Translated on 19-08-2026, 13:06.
luiggi
Post19-04-2008, 9:28    Subject: Hood Compressor Torn: How to Fix/Repair? Quote
Thank you.
I'll look into that.
No new posts P2263 - Turbocharger/Compressor, System: No Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Windshield Crack: Documentary of a 1-Year Old Car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Painting the hood Transmission, Chassis, Body & Interior
No new posts Ladeluftkühler kleben? Diesel Engine Technology
No new posts Exterior mirror glass adhesive Transmission, Chassis, Body & Interior
No new posts Folie unter Türverkleidung kleben Transmission, Chassis, Body & Interior
