Jens 16syncro
10-06-2007, 19:37 Subject: Injector Removal: AFN Engine - Guide & Tips |
I have "exposed" the fuel injectors, or more precisely, the injector holder combinations on the cylinder head of my AFN engine, meaning I have removed the fuel lines, return lines, and retaining clips.
I once tried using a 15mm open-end wrench on the nozzle holders and applied some torque, but nothing moved.
How tightly are the nozzles attached? Is there any trick to getting them out?
Thank you and best regards.
Jens. Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 13-10-2026, 6:58.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
10-06-2007, 20:46 Subject: Injector Removal: AFN Engine - Guide & Tips |
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
Profile PM WWW Garage |
Jens 16syncro
11-06-2007, 5:21 Subject: Injector Removal: AFN Engine - Guide & Tips |
Thank you, Rainer.
What should I do if I can't start the engine or get it to run?
Translated on 13-10-2026, 6:59.
11-06-2007, 6:57 Subject: Injector Removal: AFN Engine - Guide & Tips |
Besides wobbling, there's not much else left.
Jens 16syncro
11-06-2007, 9:37 Subject: Injector Removal: AFN Engine - Guide & Tips |
Rainer K. wrote: | Besides wobbling, there isn't much else left...
Screw the sliding hammer onto the nozzle?
(which I, of course, do not have  ).
How are VW or Bosch addressing this problem?
By the way...
What is the exact thread size at the top of the nozzle holder?
If I borrow a hammer drill, I'll also need a threaded adapter.
Translated on 13-10-2026, 7:00.
11-06-2007, 9:58 Subject: Injector Removal: AFN Engine - Guide & Tips |
Quote: | | If I borrow a sliding hammer, then I will also need a threaded adapter. |
Noah, right?
He has a claw that attaches exactly where you would attach the 15mm wrench.
I wouldn't want to cut corners on the threads for the electrical wiring.
m; Transparency, Teamwork
Translated on 13-10-2026, 7:01.
Profile PM Garage |
11-06-2007, 12:02 Subject: Injector Removal: AFN Engine - Guide & Tips |
Quote: | | I wouldn't want to use thread sealant on the threads for the electrical wires. |
Well spotted  . However, not everyone thinks about such things.
Translated on 13-10-2026, 7:02.
11-06-2007, 12:23 Subject: Injector Removal: AFN Engine - Guide & Tips |
<<Bloedsinn>>
Carefully lift it out using a chain and the front loader.
<</Bloedsinn>> Transparency, Teamwork
Profile PM Garage |
cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
11-06-2007, 13:48 Subject: Injector Removal: AFN Engine - Guide & Tips |
I've always used a 15mm wrench to turn them. They can sometimes be really tight, but not much can really break, unless you don't insert the wrench properly and it slips.
Sometimes, applying a rust remover to the seat beforehand can help... (the liquid doesn't drain away, so you can often achieve quite good results overnight). Man muss es nicht brauchen, aber man muss es haben!
Translated on 13-10-2026, 7:03.
Jens 16syncro
11-06-2007, 15:19 Subject: Injector Removal: AFN Engine - Guide & Tips |
Rainer K. wrote: | Quote: | | I wouldn't want to use thread locker on the threads for the electrical wires. |
Well spotted . However, not everyone thinks about such things | .
I'm already worried.
What should happen to the threads?
I once thought about cutting through an old fuel injector line and welding an M8 threaded rod to it.
Attach a suitable weight to the threaded rod, and use a nut with a large washer at the top and bottom.
The sliding hammer would be finished.
The thread would be under tension when placed over the original locking nut, so why wouldn't it be able to withstand that?
I would be more concerned about applying the sliding hammer at an angle and creating an unacceptable tilting moment. Therefore, I would not fully tighten the locking nut, but only tighten it slightly to allow for a small angular adjustment.
But let's see, tonight I'll be using the Swedish adjustable wrench  , which allows me to apply more torque.
Translated on 13-10-2026, 7:05.
Jens 16syncro
11-06-2007, 15:21 Subject: Injector Removal: AFN Engine - Guide & Tips |
dieselmartin wrote: |
Does this look like the "VW Hammer"? Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 13-10-2026, 7:06.
dieter Profi-Schrauber
Joined: 01/27/2003 Posts: 270 Karma: +13 / -0 Location: LK Uelzen
11-06-2007, 15:25 Subject: Injector Removal: AFN Engine - Guide & Tips |
Hi Jens,
If you want to try, the thread should be the same as the one used for gas pipe fittings. You should probably have something like that.
Greetings,
dieter T3 syncro 16 AFN
Translated on 13-10-2026, 7:07.
Smirf Blaumann
11-06-2007, 17:13 Subject: WD-40: Uses, Benefits, and How It Works |
Hi Jens,
I read somewhere in this forum that WD-40 might help. The idea is to let it run into the injector seats, which would supposedly cause the injectors to pop out.
Greetings, Udo.
Jens 16syncro
11-06-2007, 19:20 Subject: Injector Removal: AFN Engine - Guide & Tips |
dieter wrote: | Hi Jens,
Hello Dieter,
Nice to read from you again  .
I think I have a gas fitting lying around somewhere, I'll take a look.
I'm going to call you. Are you at the university of applied sciences?
Best regards.
Translated on 13-10-2026, 7:08.
11-06-2007, 21:39 Subject: Injector Removal: AFN Engine - Guide & Tips |
Let's hit the brakes right away before my phone starts ringing off the hook again: please, as a standard rule, DO NOT use WD40 or any other products; just follow the instructions.
WD-40 can be tested and allowed to soak for a longer period if nothing else works. However, in most cases, it creates more problems than it solves.
Translated on 13-10-2026, 7:09.
Kuhni Guest
12-06-2007, 0:13 Subject: Injector Removal: AFN Engine - Guide & Tips |
The thread is likely the same as that used for gas pipe fittings.
Don't they have left-hand threads?
Kuhni.
Translated on 13-10-2026, 7:10.
