Common 3.0L V6 TDI Engine Problems & Weaknesses
Karma: +807 / -0   Thank you, like it!
Post13-05-2007, 8:42    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
How are things currently with damage to the CR high-pressure pump in the latest 3.0L V6 TDIs?
Is this something that happens rarely, or should you expect it to occur after 150,000 km?
Do camshafts always function correctly, or do valve problems and other issues occasionally arise?
Translated on 20-10-2026, 3:45.
Herr Antje
Post13-05-2007, 9:32    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
The text discusses the newer V6 engine with a roller rocker arm design. Christians suggests that the NW (presumably a specific part or model) for the 3.0 engine is also manufactured using the same method. Perhaps this post can provide some insights into the 3.0 engine.
/viewtopic.php?t=15635&highlight=rollenschlepphebel
Unfortunately, I don't have any more information.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 20-10-2026, 3:46.
Post13-05-2007, 10:28    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
That's why my question is, I really don't want to ruin a 6-cylinder engine because of loose camshafts on the timing chain side...
Even a high-definition pump that produces foam can quickly become very, very expensive.
Therefore, we would greatly appreciate hearing from people who have been driving these engines for a longer period of time.
The goal is a small upgrade package that allows for an increase in power to approximately 320 horsepower.
Translated on 20-10-2026, 3:47.
christians
Post13-05-2007, 15:05    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
Take a look at the MT forum in the 4F section. I haven't noticed much there, except for a few instances where things seem to be performing worse than usual.
Gruß Christian
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post13-05-2007, 16:57    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
The 3.0 TDI engines are excellent engines, and so far they haven't had any known issues.
They are approximately 300% better than the old 2.5 models, which weren't even able to properly seal the valve covers.
The chain drive doesn't cause any problems, and I've only experienced one defective CR pump. However, that one didn't tolerate the gasoline icon_lol.gif.
If I had the necessary funds, I would go for the 3.0 TDI.
Given that you can get really good performance out of the engine, especially if 230 horsepower is sufficient for you. icon_twisted.gif
If you're interested, I have 2 SSPs (Service Information) about the 3.0L TDI engine in PDF format.
B.Eng (FH) u. KFZ Meister
Translated on 20-10-2026, 3:48.
mullemaus
Post13-05-2007, 17:10    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
Yes, I've already driven cars with around 300 horsepower icon_wink.gif. That's quite a bit of power icon_lol.gif.
Translated on 20-10-2026, 3:49.
vagtuning
Post13-05-2007, 17:32    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
The only real weakness of the 2.7/3.0 TDIs, especially in the beginning, was the software, but it's probably quite good now. However, the older models were just prone to problems.
Translated on 20-10-2026, 3:50.
Post13-05-2007, 17:51    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
It actually sounds quite good icon_biggrin.gif.
Thank you for the feedback!
christians
Post14-05-2007, 15:55    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
Regarding the camshafts, I first came across reports of failing camshafts online at the beginning of this year. The new cylinder heads with roller rocker arms and the redesigned camshaft were introduced, as far as I know, in 2003, which means the damage only occurs after a certain period of operation. During the development of the new engines, the issue may not have been known to Audi yet, and if it wasn't resolved earlier by chance, it could potentially become more noticeable in the next one or two years.
Gruß Christian
Translated on 20-10-2026, 3:51.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post14-05-2007, 17:34    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
christians wrote:
Regarding the camshafts, I first read about failing camshafts online at the beginning of this year. The new cylinder heads with roller rocker arms and the built-in NW (presumably a specific component) were introduced around 2003, which means the damage only occurs after a certain period of operation. During the development of the new engines, the error may not have been known even at Audi, and if it wasn't accidentally eliminated, it could potentially be observed more frequently in the next one or two years.
Um, that engine wasn't even available until around 2004. The camshafts are no longer comparable to the old ones.
I just checked the prices, and even the models from 2004 still cost over €25,000.
Translated on 20-10-2026, 3:52.
christians
Post16-05-2007, 16:08    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
Are you referring to the 3.0 engine or the BDG/BDH? The NW (Northwest) models of the 2.7 and 3.0 engines already have characteristics similar to the BDG/BDH. Of course, they are not exactly the same because the newer engines, among other things, have a different cylinder spacing. And one of the four camshafts in the 2.7/3.0 engines is made from solid material because it drives the rear-mounted timing belt.
Gruß Christian
Translated on 20-10-2026, 3:53.
dokky
2013 Volkswagen Golf
Post18-05-2007, 15:35    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
Even though it's not a lot, I have 2 customers who each own a 3.0 TDI. One has 240,000 kilometers on the clock, and the other, with an *** chip, has 143,000 kilometers. Both are running smoothly so far without any problems.
Translated on 20-10-2026, 3:54.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post23-05-2007, 10:33    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
Overall, it seems to me that the 3.0 TDI engines are significantly better than the older 2.5 TDI engines, which were often reported to have engine problems.
The car with the highest mileage listed on Mobile.de was a 3.0 TDI Audi A4 Avant with 380,000 kilometers.
By the way, we're from Austria (even though we're not just driving on Alpine passes icon_wink.gif).
It was the original engine. The only part that was replaced was the transmission, which happened at 320,000 km.
It speaks for itself, doesn't it?
Translated on 20-10-2026, 3:55.
bastion
Karma: +6 / -1   Thank you, like it!
Post26-05-2007, 12:50    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
Let's see what the rest can do first.
There are also AFB/AKN engines with 300,000 kilometers on them and with the original camshafts.
A4 Avant 08/01 AWX 05/08-
Translated on 20-10-2026, 3:56.
christians
Post15-07-2007, 15:55    Subject: Common 3.0L V6 TDI Engine Problems & Weaknesses Quote
I found something related to this topic on MT.
http://www.motor-talk.de/showthread.php?s=&postid=13234357#post13234357
"The issue with the IHU camshafts is known within the VAG group, and the reference number is 2010876/1. The camshaft lobes are not pressed onto the shaft; instead, the shaft is expanded by internal pressure, ensuring that the lobe rings fit tightly and that the recesses for the spark plug screws are present. Apparently, sometimes it's expanded "too much," haha..."
Starting with FGST numbers 8E5A097671 and 4B5N014697, alternative cam profiles are available as a standard option.
Gruß Christian
Translated on 20-10-2026, 3:57.
No new posts Used car inspection tips for TDIs Technical Articles
No new posts Repair of oil pump drive for 2.0 PD TDIs with balance shafts Troubleshooting & Guides
No new posts Forced DPF Regeneration: VAG TDI with VCDS Troubleshooting & Guides
No new posts BMW 3 Series LED License Plate Lights Transmission, Chassis, Body & Interior
No new posts ECU Software Updates: Current Versions On-Board Diagnostics (OBD)
No new posts TDI: Magnet. CR Engine, No Swirl Valves Diesel Engine Technology
No new posts Biofuel components: current efforts and prospects Diesel Engine Technology
