Marine Diesel Conversions: SDI Systems
Kopi
Post13-11-2007, 17:44    Subject: Marine Diesel Conversions: SDI Systems Quote
Hello, maybe my topic is a bit inappropriate, but I don't know what else to do.
I'm in the process of marinizing an SDi outboard motor, manufactured in 2004. I didn't realize that the fuel pump only runs with the engine control unit (ECU). Now that I'm planning to get an ECU, ignition switch, and electronic throttle, is it possible to reprogram the ECU? The goal is simply to make the engine run and display temperature, oil pressure, and RPM.
Best regards, Jan Kopmann.
Translated on 14-09-2026, 17:03.
Back to top Profile PM Email
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel 2,0 mit 170 PS? Diesel Engine Technology
No new posts LD Log A3 8P 2,0 CR-Diesel Upload
No new posts Diesel Engine Oil Diesel Engine Technology
No new posts 2-Stroke Diesel Engines: The Sequel Diesel Engine Technology
