ARL Motor Conversion, where is the line for diagnostics?
yellow5
Post30-07-2007, 12:53    Subject: ARL Motor Conversion, where is the line for diagnostics? Quote
I built an ARL engine (year 2001) into an Audi 80.
I have wired everything correctly according to the wiring diagram.
And also repeatedly checked to ensure that there is no error in the wiring.
Starter engages, Relay 109 pulls, voltage is also present.
At the WFS, it's also unlikely to work, as it would need to run in 1-2 seconds.
Before I want to get to the diagnosis first, I don't want to give up.
Does the control unit display any errors?
I can't find the K-conductor in the electrical diagram, though.
this should normally be sufficient for reading.
Does anyone know where this pipe is located?
This is my first post here on the forum, so if I've made any mistakes
Best regards, Franz
Rudi
Post30-07-2007, 13:09    Subject: ARL Motor Conversion, where is the line for diagnostics? Quote
Big Connector - Pin 16
Hi Rudi
yellow5
Post30-07-2007, 19:46    Subject: ARL Motor Conversion, where is the line for diagnostics? Quote
Hello Rudi,
Do you mean by large connector the one from the control unit?
That's because it's a "Tacho GRA Lamp" for me.
Otherwise, I can't find a plug that has a 16-position.
Best regards, Franz
Rudi
Post31-07-2007, 9:08    Subject: ARL Motor Conversion, where is the line for diagnostics? Quote
Hello Franz,
The large connector from the MSTG is already correct.
What documents should that 'GRA lamp' be placed on?
Hi Rudi
Rudi
Post31-07-2007, 9:13    Subject: ARL Motor Conversion, where is the line for diagnostics? Quote
Have you started counting from the right side?
Pin 6 is not next to the five high-current contacts.
 Stecker EDC15 - Blick auf die Kontakte des STG
 File size:  2.31 KB
 Viewed:  852 times
yellow5
Post31-07-2007, 10:37    Subject: ARL Motor Conversion, where is the line for diagnostics? Quote
Sorry, I just had a bug in my system.
At Pin 16, there is an "w". I just did a little...
googled and found out that you can also
as a k-lead for diagnosis
I didn't know that.
Best regards, Franz
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts ahu: What is this type of ductwork? Diesel Engine Technology
No new posts Fehlende K-Leitung an Instrumenten-STG? Diesel Engine Technology
No new posts Air in Pipes: Troubleshooting Starting Problems Diesel Engine Technology
No new posts Connect New ECUs to K-Line On-Board Diagnostics (OBD)
