Daytime running lights - 3BG, year 2004
Tribu
Karma: +3 / -2   Thank you, like it!
Post06-09-2008, 20:26    Subject: Daytime running lights - 3BG, year 2004 Quote
Hi fellow enthusiasts icon_smile.gif.
So, the person mentioned above (from Ireland) has daytime running lights that are constantly on, and they really don't like how the control elements of the xenon headlights work.
So, none of the suggestions helped. Maybe someone else has an idea.
I couldn't find anything about the country code.
Turn off the light switch - The plug might have 15 wires, but there's no connection between them.
Where should I look? Or should I use Vag?
According to VAG-COM:
{On-board network}
ECU coding.
Select STG 09 (On-board network).
STG Long Coding -> Function 07.
"But this control unit is not responding - I guess it's probably not available..."
Thank you in advance.
Translated on 13-07-2026, 19:32.
mullemaus
Post10-09-2008, 22:27    Subject: Daytime running lights - 3BG, year 2004 Quote
Du hast direkt am Lichtschalter den Pin - TFL. Den auspinnen und das Problem sollte gelöst sein. icon_wink.gif
PS: It says 'TFL' directly on the switch from the back icon_biggrin.gif icon_wink.gif.
Translated on 13-07-2026, 19:33.
Tribu
Post11-09-2008, 22:04    Subject: Daytime running lights - 3BG, year 2004 Quote
Okay, I'll take another look.
It didn't look like much, but it was good... icon_smile.gif It can't hurt to take a look.
Thank you...
Translated on 13-07-2026, 19:34.
Tribu
Post13-09-2008, 16:23    Subject: Daytime running lights - 3BG, year 2004 Quote
For those who are interested!
Pin B on the light switch is responsible for the parking light and the rear light when the switch is in position 0.
Musste bei diesem Irland - Import zusätzlich zu TFL abgeklemmt werden. Now it's dark.
Thanks to Mullemaus.
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Daytime Running Lights VAG-COM Installation On-Board Diagnostics (OBD)
No new posts LED control unit for daytime running lights On-Board Diagnostics (OBD)
No new posts Dim Daytime Running Lights: How & Why Transmission, Chassis, Body & Interior
No new posts Daytime Running Lights on Fog Lights 3C On-Board Diagnostics (OBD)
