Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine
dokatoto
Post07-08-2007, 6:27    Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine Quote
Which pistons need to be at the top when the crankshaft is oriented horizontally, and what is the cylinder firing order?
I can't seem to find the darn locking hole anywhere...?!
The engine can only be rotated a little bit before it stalls, which means the 'OT' (Overtime) position is not correct after the camshaft replacement...
Thank you and best regards.
Toto
christians
Post07-08-2007, 12:32    Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine Quote
During the initial installation, the 1st cylinder is the furthest forward in the direction of travel, on the right side. Count as: if in the text above = vehicle in front:
4 1
5 2
6 3
Ignition Sequence: 1-4-3-6-2-5
Gruß Christian
myfisch
Post07-08-2007, 12:34    Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine Quote
Without the locking pin, the repair seems quite daring, isn't it?
Christian is right!
Greetings
dokatoto
Post07-08-2007, 14:01    Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine Quote
I have the locking pin! But even with a pencil and ruler, the motor can only rotate a few degrees in both directions before it gets stuck...?!
Now I will remove the cams again, then the valves will be closed, in order to check whether the crankshaft is rotating freely.
and I have to find the hole again....
cksIT
Post07-08-2007, 16:17    Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine Quote
What does "a few degrees" even mean? He shouldn't be able to turn at all anymore... (there's still some play, but only minimal).
dokatoto
Post09-08-2007, 7:17    Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine Quote
So, to clarify the issue: I don't know where I inserted the screw... anyway, not into the correct hole.
Now I've taken everything apart again, and lo and behold; I've found the hole, and now everything fits perfectly again.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Position: High RPM, Fiat Stilo 1.9 JTDm Diesel Engine Technology
No new posts AAT Crankshaft Material Diesel Engine Technology
No new posts Crankshaft Vibration Dampers Diesel Engine Technology
No new posts Kurbelwelle Renault 1,9 dci Diesel Engine Technology
