Immobilizer Replacement: Questions & Answers
mickdoohan
Post09-08-2007, 12:41    Subject: Immobilizer Replacement: Questions & Answers Quote
Hello, I would like to replace the defective instrument cluster (IC/FIS) from my Audi A3 (8L) 1.8T, manufactured in 2003, which has a CAN-Bus system and IMMO3, with a new one. I have the 4-digit WFS PIN code for my current original unit.
Is this 4-digit PIN code sufficient for pairing the new key fob, or do I need to have the 4-digit PIN code regenerated into the 'new' VAG system using a 7-digit SKC code including the date, importer number, and dealer number? I am using VAG Com 402. Thank you very much for your help.
Translated on 04-08-2026, 6:22.
mullemaus
Post09-08-2007, 21:15    Subject: Immobilizer Replacement: Questions & Answers Quote
You're in the right place. icon_wink.gif And you should update your VAG-COM version.
Translated on 04-08-2026, 6:23.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit Replacement: Immobilizer Active? Diesel Engine Technology
No new posts A4, B5: Austausch Kombiinstrument,Probleme mit Dichtungen Transmission, Chassis, Body & Interior
No new posts Austausch Diesel-Kombiinstrument gegen Benziner-KI möglich? Diesel Engine Technology
No new posts 1.9 PD ASC Replacement Diesel Engine Technology
