Brake Bleeder Kit: Sodamaxx Model
highbeta
Post01-08-2007, 15:54    Subject: Brake Bleeder Kit: Sodamaxx Model Quote
I've built a brake bleeding device out of my old SodaStream.
The structure:
1. Sodamaxx. The lance, which normally extends into the water, is disassembled, and the internal hose is cut just below the bottle coupling. This prevents the CO2 from being forced through the brake fluid.
2. Screw the threaded connector into the bottom of the water bottle.
3. T-fitting.
4. a shut-off valve.
5. Pressure gauge for an operating pressure of 1.5-2 bar (here for a maximum of 6 bar).
6. 6mm PA hose.
7. Pressure-resistant cap for the vehicle's brake fluid reservoir (with a 6mm hose connection).
For operation:
Screw the adapter cap onto the brake fluid reservoir of the vehicle (ensure the level is between the minimum and maximum marks).
2. Fill approximately 0.5 liters of brake fluid into the modified water bottle.
3. With the Sodamaxx, build up a pressure of 1-2 bar with the shut-off valve closed. If there is too much pressure, you can release it using the small blue lever. Then, open the shut-off valve. The pressure will now also be applied to the braking system.
4. Bleed the system as usual. Replenish the drained brake fluid from the SodaStream bottle. If pressure needs to be 're-pressurized,' always close the shut-off valve first. The SodaStream can build up pressure of up to 6 bar, which will definitely damage the brake fluid reservoir in the car.
In my opinion, brake fluid can remain in the Sodamaxx machine under slight overpressure. The CO2 pressure should make it a better storage solution than an opened canister. The bottles are made of PET, which should be resistant to brake fluid.
Unfortunately, the device hasn't been able to be tested in a real-world scenario yet, due to the lack of a suitable cap for the brake fluid reservoir. I will try to find one from a junkyard sometime. Does anyone know of a brand where the cap also fits a VW Golf IV? Unfortunately, the original VW caps have contacts for level monitoring, which could interfere when installing a hose fitting.
According to a tool catalog, the following types should be compatible:
Adapter, thread 46.5 x 3.5 mm, short.
Standard adapter E20 for Alfa, Austin, Audi.
BMW, Citroën, Fiat, Ford, Lancia, Mercedes.
Opel, Porsche, Renault, Rover, Talbot, Volkswagen.
Volvo and Peugeot models up to 1988.
'DirkP'
 File size:  211.85 KB
 Viewed:  15265 times
 File size:  176.61 KB
 Viewed:  12751 times
 File size:  160.46 KB
 Viewed:  10279 times
Translated on 04-08-2026, 7:56.
Post01-08-2007, 15:58    Subject: Brake Bleeder Kit: Sodamaxx Model Quote
Do you work at Festo or do you get a significant commission from them?
Those cute blue connectors cost a fortune, don't they?
Translated on 04-08-2026, 8:01.
highbeta
Post01-08-2007, 16:05    Subject: Brake Bleeder Kit: Sodamaxx Model Quote
No, I don't work at Festo and I don't get any percentages. Every other connector does the same thing icon_wink.gif. The stuff was just offered because it was simply available icon_wink.gif.
Dirk.
Translated on 04-08-2026, 8:02.
christians
Post07-08-2007, 11:51    Subject: Brake Bleeder Kit: Sodamaxx Model Quote
I took a lid from a Kadett for my custom build.
Gruß Christian
oldewurtel
Post23-08-2007, 21:35    Subject: Brake Bleeder Kit: Sodamaxx Model Quote
Hello fellow enthusiasts,
Coincidentally, I had the same idea about the 'SodaMaxx' for two months, when I came across one of those devices while cleaning out my basement!
The advantages are the transparent, pressure-resistant, and sufficiently large plastic bottle. However, in my opinion, the disadvantages, such as the very thin pressure hoses that do not fit standard pneumatic accessories, and the pressure being introduced from below, outweigh the advantages. icon_wink.gif
But since 'Sodamaxx,' the idea of building a really good brake bleeding device (much better than the Eezi-Bleed in Colorado) hasn't left me alone. icon_eek.gif
When I was tidying up further and found a high-quality but defective spray nozzle from Pressol (at my place, nothing is ever thrown away, much to my wife's annoyance), I had the solution.
'Along with a specially designed cap (okay, it's not that easy to make, about an hour on the lathe, but you can also modify the old cap from the sprayer), an adjustable pressure regulator including a gauge (about 15 euros, I have mine set to approximately 1 bar), and a makeshift wooden stand (to hold both bottles when not in use), I've built a very useful device.'
The hoses, the connectors for this purpose (aquarium supplies!!), and the pneumatic components are all readily available at a well-stocked hardware store for just a few euros.
I soldered 6mm brass tubes directly into the pneumatic fittings to serve as risers.
By the way, the red lid for the oil reservoir is actually from a very old Fiesta.
Simply fill in the brake fluid, turn on the compressor, and bleed icon_biggrin.gif icon_biggrin.gif!
The pressure vessel has a volume of approximately 1.5 liters of BF and is therefore large enough to accommodate a complete 'cycle'.
BTW: Due to the (actually unnecessary) rising pipe in the collection container, it is very easy and without mess to use compressed air to push the old oil back into a dedicated 'old oil' container. Incidentally, the 90° bend for the vent valve is also very helpful. icon_wink.gif
 File size:  55.38 KB
 Viewed:  24183 times
 Entlüftungsgerät_01
 File size:  55.09 KB
 Viewed:  28672 times
Translated on 04-08-2026, 8:05.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
