AdBlue Tips & Ideas: Your Complete Guide
Post21-05-2015, 20:05    Subject: AdBlue Tips & Ideas: Your Complete Guide Quote
Hi.
Many people rely on VW's expensive 1-liter bottles because, for example, the filler neck is often located in a very inaccessible position, and you need the bottle nozzles (e.g., in the Sharan).
This evening, I noticed that an Aral gas station had apparently "displayed" empty 10-20 liter canisters in a wire box, presumably for nighttime collection.
All the canisters still had their long spouts clipped into the designated slot.
Possibly, you could take one of those to build funnels.
Greetings.
Translated on 28-10-2026, 10:07.
vwSchrauber
Post22-05-2015, 11:57    Subject: AdBlue Tips & Ideas: Your Complete Guide Quote
We have, for example, ~10-liter canisters with a long, flexible filling spout icon_wink.gif.
Translated on 28-10-2026, 10:08.
Post22-05-2015, 15:53    Subject: AdBlue Tips & Ideas: Your Complete Guide Quote
But make sure to clean the nozzles thoroughly. This stuff crystallizes very quickly...
"What's the problem with filling the Sharan with water using a tap? If you're not particularly uncoordinated or lacking in mechanical aptitude, it's quite doable... However, if the trunk is full and you need to top up the water in an emergency, then none of that helps."
No new posts Tips and tricks for care and crafting Technical Articles
No new posts Battery Care: Tips for Checking and Maintenance Technical Articles
No new posts AdBlue Refill: Tips & Tricks Diesel Engine Technology
No new posts AdBlue System Error: Defective Quality Sensor? On-Board Diagnostics (OBD)
No new posts TDI Ultra Engines: AdBlue Consumption Diesel Engine Technology
No new posts Cooling Charge Air: Ideas & Tips Diesel Engine Technology
