Fuel Injector Clogged After 84,000 km?
reuselkopp
Post25-09-2007, 14:30    Subject: Fuel Injector Clogged After 84,000 km? Quote
Is it possible that the quantity control valve in the pump is already clogged after only 84,000 km? In my AFN, a replacement pump from icon_smile.gif was installed about 2.5 years ago. Unfortunately, I now experience a slight jerking/vibration when accelerating from the low RPM range (1000-2200 RPM) in the higher gears.
Could it really be the familiar "jerking" sensation caused by a dirty fuel injector control valve? Already now? I thought that would only occur with significantly higher mileage (>180,000).
What exactly does "exchange" mean in this context? Does it mean receiving a used part that has been repaired? What exactly is repaired on a pump when it is exchanged?
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 17-09-2026, 18:04.
cksIT
Post26-09-2007, 6:48    Subject: Fuel Injector Clogged After 84,000 km? Quote
The problem with the MSW only occurred with the 1Z model...
Does the Variant possibly have a ZMS? That could also cause jerking.
If it were a faulty MSW (in the 1Z model), you would mainly experience the severe jerking during light acceleration or when trying to maintain speed in traffic.
Translated on 17-09-2026, 18:05.
reuselkopp
Post26-09-2007, 7:28    Subject: Fuel Injector Clogged After 84,000 km? Quote
"As far as I know, and as I've also read here, this jerking can occur in all VP37 TDI engines. It's more of a slight jerk during acceleration, but also when cruising in traffic. Sometimes I experience this jerk even at higher RPMs (around -2700 RPM)."
I don't know if my variant has a ZMS. How can I find out?
Translated on 17-09-2026, 18:06.
Post26-09-2007, 8:07    Subject: Fuel Injector Clogged After 84,000 km? Quote
My knowledge:
1Z no ZMS.
AFN (in the G3) has one.
Translated on 17-09-2026, 18:07.
cksIT
Post26-09-2007, 8:43    Subject: Fuel Injector Clogged After 84,000 km? Quote
If that's correct, then it's probably the ZMS (likely referring to a specific component). Is the engine chipped, or how many kilometers does it have on it now?
I was just unsure because that's definitely the case for the ones installed lengthwise (1Z = EMS; AFN = ZMS).
Translated on 17-09-2026, 18:08.
reuselkopp
Post26-09-2007, 9:02    Subject: Fuel Injector Clogged After 84,000 km? Quote
My heating oil truck has now driven 209,000 km, and it hasn't been chipped. What could possibly go wrong with the dual-mass flywheel (ZMS)? It's such a pain if it's actually defective, because I had the transmission removed just 10,000 km ago to replace the ASD (Automatic Speed ​​Disengagement).
How can you determine if the dual-mass flywheel (DMF) is defective? I don't understand the "back-and-forth sliding" method that's described in this forum.
cksIT
Post26-09-2007, 11:35    Subject: Fuel Injector Clogged After 84,000 km? Quote
The ZMS (presumably a component) can "break down" because it consists of two parts that can separate from each other. This can then cause a strange vibration or jerking. It can sometimes be quite severe.
It's possible that even with the original performance, it could break down due to mileage.
I'm not sure if you have a ZMS installed or not...
Translated on 17-09-2026, 18:09.
No new posts Quantity setting device and control path generator: Function Technical Articles
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VP37 ESP: Cleaned Powder Meter According to Instructions. Diesel Engine Technology
No new posts ZKD Failure: Replacing After 45,000 km Diesel Engine Technology
No new posts ASZ and clutch worn out after only 28,000 km? Diesel Engine Technology
No new posts Clutch Worn Out After 14,000 km? Diesel Engine Technology
