Conti SportContact 2: Buy One or Two?
Post04-10-2007, 9:59    Subject: Conti SportContact 2: Buy One or Two? Quote
Hi.
I got a screw stuck in one of my Conti SportContact 2 tires on Tuesday.
The devices have been used for 12,000 kilometers (and have only been in use for half a year).
The screw was deeply embedded and located on the very edge. Therefore, a repair is not possible.
Now the question is, should I get ONE or TWO new ones?
- While SC2 is still in the program, it may be becoming increasingly scarce.
- I then got a new tire for the rear left, and a tire with 12,000 km on it for the rear right. How will that affect things if I need to move those tires to the front?
Ahhh, those beautiful tires! The 235/45 WR 17s are calling my name with a nice price.
Translated on 08-10-2026, 15:27.
Post04-10-2007, 10:08    Subject: Conti SportContact 2: Buy One or Two? Quote
Was the tire only on the rear before?
He probably didn't lose much performance. Check the measurements. If you make sure to get fresh tires when replacing them, there shouldn't be any reason not to use them. The situation would be different for the front tires, depending on your driving style. Differences in rolling circumference can then cause problems with the ABS/ESP system if the tires are used prematurely.
Translated on 08-10-2026, 15:29.
Post04-10-2007, 11:15    Subject: Conti SportContact 2: Buy One or Two? Quote
The tire was located in the FRONT of the vehicle from kilometer 5000 to kilometer 14572.
Then all 4 were re-weighed, and the V and H were swapped. Finally, at 17950, the screw came loose.
The defect has just now worn down the mini-groove https://community.dieselschrauber.org/en/viewtopic.php?t=15624.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post04-10-2007, 13:58    Subject: Conti SportContact 2: Buy One or Two? Quote
A friend had his stuck VR (variable valve lift) on his Golf repaired in his workshop. Someone used a vulcanized and machined plug to fix it, and he hasn't had any problems, even though he has the "heat management" system! However, officially, no one does this kind of repair.
Okay, so either two new tires for the rear or two for the front, depending on how different the tread patterns are.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 08-10-2026, 15:30.
Post08-10-2007, 18:32    Subject: Conti SportContact 2: Buy One or Two? Quote
The repair is not necessary because the damage is only on the very outer surface.
The other rear tire has 5.8 mm of tread left.
I'll just have the defective tire replaced for now.
Translated on 08-10-2026, 15:31.
Post09-10-2007, 7:36    Subject: Conti SportContact 2: Buy One or Two? Quote
So, first of all: this is annoying.
Don't take Martin too seriously: Wouldn't it be a great way to test your tire pressure monitoring system...?
*quickly away*
Translated on 08-10-2026, 15:32.
Post09-10-2007, 8:02    Subject: Conti SportContact 2: Buy One or Two? Quote
I already have.
I once let out 0.2 bar of air. Because 2.5 bar should still be enough for a 235 even in the city. But she didn't notice.
(but it was actually that tire that's now flat).
It seems you actually need the button to put them into learning mode.
No new posts Calix Motor Heater Installation Guide Troubleshooting & Guides
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts ZR-W replacement for V6 TDI engines, or "How to destroy a... Diesel Engine Technology
No new posts Continental Winter Tires Transmission, Chassis, Body & Interior
No new posts Which Conti timing belt kit fits the AFN engine in the VW... Diesel Engine Technology
No new posts Sudden rear instability with new Conti Sport Contact 5? Transmission, Chassis, Body & Interior
