AFN: Temporary Performance Issues
caddy
Post09-02-2003, 17:54    Subject: AFN: Temporary Performance Issues Quote
'Yesterday, I experienced a loss of power across the entire RPM range for the second time, after driving about 30 km at a leisurely pace. My boost pressure gauge then only showed half the normal pressure. When you release the accelerator and then fully press it again, the boost pressure only rises to a quarter of the normal full-load value. The next day, the engine runs normally again.'
I've already been looking for leaks in the hydraulic system, but I haven't found any yet. Perhaps someone has a tip on how to best check the pressure system for leaks. Simply running the engine at high speed while stationary doesn't build up much pressure.
Best regards, caddy.
Translated on 21-10-2026, 17:44.
Post09-02-2003, 18:43    Subject: AFN: Temporary Performance Issues Quote
Hi.
Leaks in the pressurized area become noticeable under load through hissing/whistling sounds and external oil leakage.
As long as neither of those things is the case, I would first check the valve timing gear (VTG) for smooth operation.
--> Technical articles, error database, search function. Should be enough for a few hours of reading... icon_cool.gif
Translated on 21-10-2026, 17:45.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN: Temporary Performance Issues Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
