ABS Light On: Troubleshooting & Solutions
bakkano
Post21-11-2007, 15:23    Subject: ABS Light On: Troubleshooting & Solutions Quote
Hi everyone,
The ABS light has been on in my car for a while now.
The error log showed intermittent faults for the front left and rear right sensors.
Okay.
Then, eventually, a permanent error.
Both sensors have been replaced.
Still not okay.
Vo Re still has a bug.
Then I bought a new sensor again and installed it.
Unfortunately, there is still no improvement.
Control unit part number: 1J0 907 379 G.
Component and/or version: ABS 20 IE CAN 0001
Encoding: 03304
Workshop code: WSC 00046.
"One error found:"
00285 - Front right speed sensor (G45)
35-00 - -
What else can I do?
Sascha.
Translated on 26-10-2026, 0:46.
Post21-11-2007, 15:45    Subject: ABS Light On: Troubleshooting & Solutions Quote
...check all cables and connectors (between the control unit and the sensor).
And that doesn't just mean "watching," but actually testing it with a continuous, uninterrupted run.
Translated on 26-10-2026, 0:48.
bakkano
Post21-11-2007, 15:51    Subject: ABS Light On: Troubleshooting & Solutions Quote
Okay, here's the translation:
"Good answer."
Why didn't I think of that myself...?
Sometimes, when you're looking at the forest, you can't see the trees.
What should the resistance values be?
"It's not that the cable is broken, but that the resistance is incorrect, and I'm worried about getting electrocuted."
Translated on 26-10-2026, 0:49.
heizfoss
Karma: +4 / -1   Thank you, like it!
Post21-11-2007, 22:50    Subject: ABS Light On: Troubleshooting & Solutions Quote
Hello bakkano,
"Just pinging it is enough; the cables from the control unit to the sensor are simply connections."
Aber schau mal ob der Stecker auf dem Steuergerät richtig sitzt. Please pay particular attention to this.
"Check if there is any moisture inside the large connector on the ABS/ESP control unit."
I don't know what kind of vehicle you have, but there have been occasional problems with...
"Flooding" from such connectors, and then there were interactions due to leakage currents between the many pins.
Here's another thing: Some ABS/ESP control units only turn off the warning light after a diagnostic fault (DF) if they receive a valid wheel speed signal again. This means you may need to briefly drive the vehicle (above 20 km/h) and then perform another ignition reset.
I hope you find the problem.
Greetings, heizfoss icon_lol.gif.
icon_smile.gif Spritsparen durch Ausnutzen der Querbeschleunigung - lieber tot als Schwung verlieren
Translated on 26-10-2026, 0:50.
Post23-11-2007, 19:07    Subject: ABS Light On: Troubleshooting & Solutions Quote
Don't forget to check the ABS wheel speed sensor. If this part has missing teeth, is bent, or is covered in rust, it won't produce a proper signal.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 26-10-2026, 0:52.
Post23-11-2007, 19:48    Subject: ABS Light On: Troubleshooting & Solutions Quote
guste100 wrote:
Don't forget to check the ABS sensor wheel. If this part has missing teeth, is bent, or is covered in rust, it will no longer produce a proper signal.
Guste
Copper paste from the brakes, grease from the driveshaft boot, and road grime are also commonly found contaminants.
bakkano
Post24-11-2007, 12:43    Subject: ABS Light On: Troubleshooting & Solutions Quote
Thank you for the answers.
Fortunately, the problem has been resolved.
It was a direct cable break at the connector itself.
The sensor and other components are working correctly.
Sascha.
Translated on 26-10-2026, 0:53.
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP Light On: What It Means & Troubleshooting Diesel Engine Technology
No new posts ESP Light On: Brake Booster Failure? On-Board Diagnostics (OBD)
No new posts ESP Light On After Tuning: Troubleshooting Diesel Engine Technology
No new posts ABS Light On: Troubleshooting Air in Brake Lines On-Board Diagnostics (OBD)
