VAG Struts: New Suspension Upgrade
kossmann
2016 Audi Q3
Post11-12-2007, 10:06    Subject: VAG Struts: New Suspension Upgrade Quote
Hello everyone,
Did I read that correctly while browsing the forum?
When installing a new suspension system (shocks and springs), the front strut mounts should definitely be replaced as well. Purchase genuine VAG strut mounts; do not buy aftermarket ones!
There are no strut mounts in the rear of the Audi 80 Avant (B4) 1.9 TDI (1Z) that need to be replaced, right?
What is the name of the strut mounts in the catalog (for the part numbers)? Is it the "mounting bracket" with the number "8A0 412 323 D"?
What about the Meyle reinforced parts? You can find very different opinions about them icon_confused.gif.
Thank you!
Translated on 20-08-2026, 1:23.
No new posts Domlager Transmission, Chassis, Body & Interior
No new posts Defective steering knuckle or wishbone bearings? Transmission, Chassis, Body & Interior
No new posts Domlager wechseln am Golf 4 ohne Federbeinausbau? Transmission, Chassis, Body & Interior
No new posts agr new problem Diesel Engine Technology
