Seat Alhambra: 90 TDI won't start? Troubleshooting.
stef
Post03-12-2007, 8:46    Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. Quote
hello forum
"For a few days now, sometimes when I turn off the engine, it continues to run for a few seconds before it shuts off."
The car is a Seat Alhambra, with an AHU engine, manufactured in 1998.
Fix the issue by checking relay 109.
or is there something wrong with the ignition switch?
stef
Translated on 24-10-2026, 8:24.
Back to top Profile PM Email
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post03-12-2007, 14:19    Subject: To be or not to be? Quote
Hello, the easiest thing would probably be to make the relay accessible, and then, if it doesn't turn off properly, quickly pull the relay.
Or you could try putting in a new one, just to see. I don't think it's the ignition switch. It's either completely off or completely on.
Doesn't he have a bypass valve that isn't working?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 24-10-2026, 8:25.
stef
Post03-12-2007, 15:27    Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. Quote
hello
Okay, I noticed today that the engine keeps running even when I'm letting off the gas!
Okay, it's related to the contactor relay. I've pulled almost all the relays, and it's still staying on.
I will take a very close look at it tonight.
stef
Translated on 24-10-2026, 8:26.
mullemaus
Post04-12-2007, 0:30    Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. Quote
Translated on 24-10-2026, 8:27.
Post04-12-2007, 6:26    Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. Quote
stef wrote:
So, I noticed today that the sound remains on even when it's supposed to be turning off!!
I suspect there's a short circuit in the wiring leading to the reverse lights, where voltage is being supplied (sporadically?) regardless of the gear selected.
The reverse gear then closes the switch connection to terminal 15, which then no longer requires contact from the ignition switch to carry voltage.
Translated on 24-10-2026, 8:28.
stef
Post04-12-2007, 14:14    Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. Quote
hello
I found this today.
There was a broken cable connected to the tailgate, all the cables were damaged, and there was a short circuit in the taillights.
Thank you for the tips.
stef
Translated on 24-10-2026, 8:29.
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Alhambra 2.0 TDI Upload
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Alhambra TDI: Small Engine Problem? Diesel Engine Technology
