bakkano Schrauber
06-12-2007, 18:04 Subject: Overshoot and Vibration: Causes & Solutions |
I have a rather strange question.
Can excessive masturbation cause strange "vibrations" to originate from the front of the body?
It's not exactly a jerky movement either.
It's hard to describe what's going on right now; I'm not sure how to express it better.
Does anyone recognize this?
Sascha.
Translated on 30-10-2026, 16:52.
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
06-12-2007, 18:17 Subject: Overshoot and Vibration: Causes & Solutions |
Quote: | It's difficult to describe what's happening right now, I don't know how to express it better.
Unfortunately, that won't work like that, unless we use a crystal ball  .
Okay, I will translate the German text into English and try to provide more descriptive details. Please provide the text you would like me to translate. 3B5 AJM
Translated on 30-10-2026, 16:53.
Jochen_145 Guest
06-12-2007, 18:22 Subject: Overshoot and Vibration: Causes & Solutions |
It is quite possible that, due to the over-advancing of the timing, the amount of fuel injected increases due to the additional air mass.
Depending on the software, this can release significant amounts of extra power, which can put more strain on the ZMS (torque management system) or the clutch, potentially leading to jerking or surging.
You can then notice it through 'vibrations,' etc., although this is now very faintly visible.
This behavior is only observed with tuning software and is to be expected due to the limitations imposed by the smoke reduction feature.
In the case of mass-produced software, the excess quantity due to overproduction is not very large. Additionally, work is being done on limiting the rotational speed, which prevents the excess air mass from being fully utilized in the fuel injection system.
Best regards, Jochen.
Translated on 30-10-2026, 16:55.
bakkano Schrauber
06-12-2007, 18:52 Subject: Overshoot and Vibration: Causes & Solutions |
Okay, that's already helpful.
I just remembered that it actually only happens in the 4th and 5th gears when I'm giving it full throttle, within the RPM range of 1800 to around 2200.
Translated on 30-10-2026, 16:56.
BM Profi-Schrauber
06-12-2007, 21:14 Subject: Overshoot and Vibration: Causes & Solutions |
Quote: | Depending on the software, this can release significant additional amounts, which can put more strain on the ZMS (torque management system) or the clutch, potentially leading to jerking or surging.
You can then notice it through "vibrations" etc., which are now very widely visible. |
It might be, but it doesn't have to be. It's also possible that one of the inner constant velocity joints is faulty, or something else...
That's why I'm asking. Some information about the vehicle would also be helpful. 3B5 AJM
Translated on 30-10-2026, 16:57.
bakkano Schrauber
07-12-2007, 8:48 Subject: Overshoot and Vibration: Causes & Solutions |
Oh dear.
I always forget the important things.
Also ist ein 1.9 TDI AHF mit 110 PS. Bj. 98. 145000. Chip installed for 6000 km.
Equipped with a chip (not from DKW), producing approximately 140 horsepower.
The vibrations might also be coming from the clutch.
Let's see.
Translated on 30-10-2026, 16:58.
makrospex Blaumann
07-12-2007, 14:14 Subject: Overshoot and Vibration: Causes & Solutions |
Based on the RPM range where the vibrations occur, I'd suspect the dual-mass flywheel (DMF) of the clutch.
"Pulse the clutch pedal to find the engagement point."
Clicking sounds in time with the engine speed.
If these two symptoms also occur, it is very likely due to the clutch/dual-mass flywheel.
I've already had four of those (in two cars)...
macro Opel Vivaro Kombi, 2.0 CDTI 110kW BlueHDI (MKB: AH01), BJ 2020
Translated on 30-10-2026, 16:59.
