Engine Start Problems: Hard Knocking Noise
donalexo
Post11-11-2007, 21:06    Subject: Engine Start Problems: Hard Knocking Noise Quote
Hello everyone,
"Recently, when starting my Audi A3 engine, there's been a noticeable loud bang. After the starter motor reaches the start speed, the engine kicks in with a hard thud (a "kawumm" sound)."
I find this behavior a bit strange, especially since it doesn't sound very healthy for the engine.
What could be the cause? The initial amount was not adjusted upwards.
Could a leaky injector nozzle be a possible explanation? If diesel continues to drip into the combustion chamber from the fuel line due to residual pressure after the engine is turned off, and then ignites abruptly when the engine starts...
Hopefully not, because the injectors are still relatively new (they've only been used for about 50,000 kilometers).
Thank you for your theses/proposals.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 11-08-2026, 21:30.
Post11-11-2007, 21:33    Subject: Engine Start Problems: Hard Knock Noise Quote
donalexo wrote:
Could a dripping nozzle be a possible explanation? If, after stopping the engine, diesel continues to drip into the cylinder due to residual pressure in the line, and then ignites abruptly during engine start...
Hi Alex,
I find that less likely because the fuel injection amount during startup and warm-up, depending on engine temperature, is close to or even below the stoichiometric air-fuel ratio (lambda = 1).
Additional diesel fuel (from a puddle in one cylinder chamber) could therefore, in my opinion, hardly be converted into a "particularly violent" combustion due to the lack of usable oxygen in the cylinder icon_rolleyes.gif.
I'm more inclined to think it might be a delayed ignition: some air gets blown out in front of the injector nozzles before the diesel arrives, preventing normal pre-injection, and the "bang" is a single, sharp combustion event.
The question is how air keeps getting into the system - could it be a faulty pressure relief valve?
Could the knocking sound possibly be caused by something mechanical (like the engine shaking against something), rather than an ignition problem?
Translated on 11-08-2026, 21:33.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post11-11-2007, 23:04    Subject: Engine Start Problems: Hard Knocking Noise Quote
My first thought was something mechanical, like a loose torque support.
Then it occurred to me that you had the clutch replaced, which confirms my suspicion.
Was everything reassembled correctly during the installation? Was the flywheel also replaced, since foreign objects entered and damaged the clutch?
Ich könnte mir vorstellen dass dieser Schlag dadurch entsteht, dass der Starter die Schwungscheibe gegen den widerstand des Motors anstartet. As far as I can tell, everything is normal.
When the first ignition occurs in the cylinders, the crankshaft kicks against the flywheel.
Almost from one attack to another.
Since I didn't remove the flywheel during my clutch replacement, I don't know how it's secured. Is it only held in place by the four screws, or is it also fixed in a specific position by a groove or pin?
Translated on 11-08-2026, 21:35.
Tagessuppe
Post18-12-2007, 13:55    Subject: Engine Start Problems: Hard Knocking Noise Quote
And? Are you still driving around with a faulty engine?
Translated on 11-08-2026, 21:37.
donalexo
Post20-12-2007, 23:39    Subject: Engine Start Problems: Hard Knocking Noise Quote
Yes, the engine is still misfiring during cold starts.
I can rule out a loose aggregate mount or a damaged pedestal support because I checked them about two weeks ago during the oil change.
I've already gotten so used to the "WUMMMS" sound during startup... icon_wink.gif
Alex.
Stefan-TDI
1997 Volkswagen Golf
Post22-12-2007, 20:02    Subject: Engine Start Problems: Hard Knocking Noise Quote
Do you still feel the "kick" even when it's gradually increasing?
Translated on 11-08-2026, 21:38.
No new posts MKB ABC: Engine Start Issues After MSG Replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Warped Brake Disc: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts New tow hitch... and the impact that hit me! Transmission, Chassis, Body & Interior
No new posts Audi 80 B4: Jerking When Starting - Fix! Transmission, Chassis, Body & Interior
No new posts Driving Performance: Maximize Power Now! Diesel Engine Technology
