How do I get speaker wire into the rear doors?
S_Freak
Post08-05-2002, 11:12    Subject: How do I get speaker wire into the rear doors? Quote
Hey everyone,
I want to install speaker wires in my Variant TDI now, and for that, I disconnected the connector between the door and the body. Unfortunately, the plug fills the entire sleeve, so I can't get any cables past it.
Does anyone have a solution for me other than possibly drilling through the metal?
MsG
S_Freak
thomas.diem
Post08-05-2002, 12:51    Subject: How do I get speaker wire into the rear doors? Quote
Hello S_Freak,
The connector is likely not fully seated. I pushed the two speaker cables through two unused holes, and it worked quite well for me.
Thomas
Jonny1303
Post08-05-2002, 15:50    Subject: Plug in the plug as the cleanest solution Quote
Hello S_Freak,
The rubber sleeve can be pulled off the connector.
Then you need cables with a pin at the end that simply plug into the connector.
Unfortunately, VW is being a pain again. The cables they have in stock are too short, so you'll have to buy half the amount (remember, they have connectors on both ends!), and then cut them in half, because you'll have to solder them anyway on the speaker side (so you'll end up with two cables total).
On the B-pillar side, it's different; small plugs go into the larger ones.
By the way: If you intend to do the same thing with the A-pillar, BE CAREFUL!
VW installed parts that don't have a part number icon_wink.gif, so you may need to order all the connectors that don't have a number (for example, I ordered all the 10-pin connectors...).
Have fun!
Jürgen.
No new posts Doku Golf III, Korrosion an hinteren Türen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat MJ 2000, Geräusch der hinteren Faustsattelbr... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Are rear door speaker wires already pre-installed in the G4? Transmission, Chassis, Body & Interior
No new posts ZV öffnet die hinteren Türen nicht Electrical Systems, Vehicle Electronics, Multimedia
No new posts Probleme mit hinteren Türen, Öffnung wird nicht erkannt. On-Board Diagnostics (OBD)
No new posts Wo bekomme ich Labeldatei für Golf 3 Tdi Diesel Engine Technology
