johnwolf
10-11-2022, 18:40 Subject: Disable T4 WFS: How to & Troubleshooting |
Hi, I've been having this problem for weeks now with my T4 2.5 petrol from 1995: it starts sometimes for a few days, then it won't start again.
I replaced the ignition switch, starter motor, and ignition coil.
I only have one key, but I don't think the problem is with the chip inside the key.
At VW, they wanted 156 euros for a new key.
No, I won't do that, as it probably wouldn't solve the problem.
Then, VW wanted to run a diagnostic test on the 200e to determine if there were any defects or malfunctions.
"No, I'm not doing that either; I think they're trying to rip me off out here in the countryside."
Okay, here's the translation:
"Now my question is, do I even need to bother with this? In other words, is it possible to disable the WFS (Workshop Information System) through software on my old car? And what would that cost me? Surely a hundred [currency unit] should be enough, right? It's not going to take 2-3 hours of work, is it?"
"Thank you."
Translated on 12-08-2026, 18:41.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1508 Karma: +643 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
dieselschrauber likes this. |
10-11-2022, 20:20 Subject: Disable T4 WFS: How to & Troubleshooting |
The WFS (Weather Forecasting System) needs to be reprogrammed, and workshops cannot do that.
How does it manifest itself? Does it turn on for a second and then off?
Is the error memory full?
Translated on 12-08-2026, 18:43.
Profile PM Garage |
johnwolf
10-11-2022, 20:30 Subject: Disable T4 WFS: How to & Troubleshooting |
On "good" days, it just runs, even if I turn it off and on. It keeps running.
On bad days, like yesterday, I tried to start it in the morning and evening. It would start up five times in a row, but then turn off after 1-2 seconds.
"Can anyone help me program this? Or do I really have to replace the WFS and keys?"
is this the diagnosis section?
| Description: |
| File size: |
101.9 KB |
| Viewed: |
6808 times |
Translated on 12-08-2026, 18:44.
E30_V8 Profi-Schrauber
Joined: 06/15/2022 Posts: 94 Karma: +111 / -0 Location: ...aus dem Herzen der Natur! 2005 Skoda Fabia  Premium Support
10-11-2022, 23:31 Subject: Disable T4 WFS: How to & Troubleshooting |
This symptom can have several causes, and there are plenty of examples here in the forum. However, it seems that the WFS is already identified as the likely culprit...
Has everything else that might be relevant already been checked?
Quote: | | I have replaced the ignition switch, starter motor, and pickup coil. | Does "starter motor" refer to the electrical part of the ignition switch, specifically the starter solenoid?
The item marked on the photo is the 2x2 diagnostic interface.
Best regards from Hesse.
P.S.
The Shift key seems to malfunction occasionally.
Polo V 1,6 Tdi (CAY)
Translated on 12-08-2026, 18:45.
Profile PM Garage |
johnwolf
10-11-2022, 23:45 Subject: Disable T4 WFS: How to & Troubleshooting |
E30_V8 wrote: | Hello,
Okay, I meant the ignition switch.
Okay, then I'll look for a workshop that still carries the "2x2" device. Thanks.
Translated on 12-08-2026, 18:47.
10-11-2022, 23:50 Subject: Disable T4 WFS: How to & Troubleshooting |
There are also OBD2 to 2x2 adapters available.
Translated on 12-08-2026, 18:48.
Profile PM Garage |
11-11-2022, 7:09 Subject: Disable T4 WFS: How to & Troubleshooting |
To find a solution, you can search online using "Dr. Google," as there are many companies that offer this service.
I would either purchase an MSG (Message Service Gateway) and have the WFS (Web Feature Server) functionality disabled, or I would buy one that already has the WFS functionality disabled.
Translated on 12-08-2026, 18:49.
Profile PM Garage |
johnwolf
11-11-2022, 8:19 Subject: Disable T4 WFS: How to & Troubleshooting |
Rüdi wrote: | To find out how to reprogram it, ask Dr. Google; there are tons of companies that offer this service.
I would either purchase an MSG and have the WFS functionality programmed out of it, or buy one that already has the WFS disabled. |
Morning, I'm confused, does the WFS need to be addressed through MSG?
I thought I would solve that within the WFS itself.
| Description: |
| File size: |
3.29 MB |
| Viewed: |
990 times |
Translated on 12-08-2026, 18:50.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2400 Karma: +437 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
11-11-2022, 9:26 Subject: Disable T4 WFS: How to & Troubleshooting |
johnwolf wrote: | Good morning, I'm confused, does the WFS need to be accessed through MSG?
I thought I would solve that WITHIN the WFS itself | .
Who controls the engine  ?
The engine control unit (MSG) communicates with the wheel theft system (WFS) via a data line. It checks whether the WFS has recognized a valid key. If not, the MSG shuts off the engine.
A corresponding control module (MSG) doesn't even check if a water pump system (WFS) is installed and simply allows the engine to run.
Therefore, only the MSG needs to be swapped with one that has its WFS disabled.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 12-08-2026, 18:51.
Profile PM Garage |
johnwolf
11-11-2022, 9:41 Subject: Disable T4 WFS: How to & Troubleshooting |
Thank you all.
Translated on 12-08-2026, 18:53.
Joined: 04/12/2002 Posts: 18063 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
11-11-2022, 12:42 Subject: Disable T4 WFS: How to & Troubleshooting |
Profile PM WWW Garage |
johnwolf
17-11-2022, 11:37 Subject: Disable T4 WFS: How to & Troubleshooting |
"Good day, I was surprised to discover that there are also Swiss people active in this forum; I'm from Basel."
However, I now suspect that the MSG is malfunctioning because it runs for one day and then doesn't work at all the next.
"Is there anyone in the Aargau/Basel-Landschaft/Basel-Stadt region who is a member and might be able to help with troubleshooting payment issues?"
Best regards.
john
Translated on 12-08-2026, 18:54.
Herbert Profi-Schrauber
dieselschrauber and johnwolf likes this. |
17-11-2022, 13:02 Subject: Disable T4 WFS: How to & Troubleshooting |
What about the second key?
I just mean... the immobilizer is activated, the ignition switch and reading coil need to be replaced... only one key.
A workshop would be willing to show the documents here.
Translated on 12-08-2026, 18:55.
johnwolf
17-11-2022, 13:42 Subject: Disable T4 WFS: How to & Troubleshooting |
"The T4 is my most modern car, so the complexity wasn't immediately apparent. It wasn't known that the T4 was chipped until someone tried to copy the key. This was only noticed after the loss of the second key."
17-11-2022, 18:06 Subject: Disable T4 WFS: How to & Troubleshooting |
As a test, you could try to see how a new transponder is programmed for older vehicles. It might be possible that this can be done easily (with an existing key). However, it's also possible that you would need the correct login PIN for that process.
If it's a simple fix, you can buy the transponder separately for a small amount of money. It would be worth trying if there isn't a second key available.
Translated on 12-08-2026, 18:56.
Profile PM Garage |
johnwolf
18-11-2022, 7:54 Subject: Disable T4 WFS: How to & Troubleshooting |
hello guste100
I did some research and was planning to buy your VCDS HEX-V2, but now I've read something else.
Can vehicle keys be programmed using VCDS?
The "Remote Control" function for the central locking system can be programmed (adjusted) using VCDS. The "Transponder programming (adjustment)" function would only be possible with older vehicles and in conjunction with the vehicle-specific immobilizer code. The vehicle-specific immobilizer code cannot be read out using VCDS.
Okay, so if that doesn't work, I don't see any advantage to it. Then I'll just get the (OBD2 diagnostic kit). Does the (VCDS) do nothing then, or am I misunderstanding something?
and p.s. https://www.buymeacoffee.com/Dieselschrauber I hope it arrives warm, hahaha.
Translated on 12-08-2026, 18:58.
