Vehicle Front Alignment Tool for Service
KombiBlue
Post11-09-2003, 16:50    Subject: Vehicle Front Alignment Tool for Service Quote
Hello, I would like to build a tool to bring the front of a Passat 3B into the service position.
Can someone help me with pictures and/or drawings, and dimensions?
Thank you for your help.
Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB
Translated on 24-09-2026, 10:33.
dr_braun
Tagessuppe likes this.
Post11-09-2003, 18:12    Subject: Vehicle Front Alignment Tool for Service Quote
'These are simply two metal sleeves with two 8mm screws running through them. They are approximately 8cm long, and the screws are correspondingly longer, around 9.5-10cm. The sleeves have a diameter of about 2cm and serve only as guides, so that the front panel is fixed in place and cannot fall down.'
Sincerely, Dr. Braun.
Translated on 24-09-2026, 10:34.
KombiBlue
Post15-09-2003, 10:24    Subject: Vehicle Front Alignment Tool for Service Quote
Hello, and thank you for your reply.
Where else have I read about a diameter of 16mm?
I can also imagine that if the front part is hanging on a pipe that is only 80mm long, it could bend quite a bit under the leverage.
Who can provide me with more detailed information now?
Thank you.
Gruss Ralf
Translated on 24-09-2026, 10:35.
dr_braun
Post15-09-2003, 19:10    Subject: Vehicle Front Alignment Tool for Service Quote
'Yes, it's possible that the 16mm ones are strong, but unfortunately, I can't remember exactly. I've owned many Passats and A4s with parts in the service position, and I've never had anything bend or warp in those areas.'
No new posts New Spark Plugs: Benefits & Performance Boost Diesel Engine Technology
No new posts Soot emission reduction. Will it make a difference? Diesel Engine Technology
No new posts Workshops are driving me to despair: LLK is leaking Diesel Engine Technology
No new posts Tool durability test: Does it last? Diesel Engine Technology
