Polo MJ 2002: Stuck A/C or Recirculation Button (Solution)
Michael II
Post30-12-2002, 16:15    Subject: Polo MJ 2002: Stuck A/C or Recirculation Button Quote
Polo MJ 2002: The recirculation or AC button occasionally gets stuck.
Cause:
When the recirculation or AC button is pressed, it may occasionally get stuck. In this case, the button will make contact with the surrounding panel.
Solution:
Please check if the recirculation button or the AC button is still sticking even with the panel removed. If this is not the case, please realign the heating and fresh air controls, as well as the panel. If this does not resolve the issue, the panel needs to be reworked. There must be no contact between the buttons and the panel.
Tschüss
Michael II
Translated on 26-10-2026, 12:29.
Ratings - Polo MJ 2002: Stuck A/C or Recirculation Button
No new posts Document A2 8Z0 KJ 2002, Steering lock jammed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2002, Gearbox noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo MK4 AC Noise: Diagnosis & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: No Central Locking on Polo 1.4 TDI (2002) On-Board Diagnostics (OBD)
No new posts Climatronic / Air Circulation Motor / TICKING On-Board Diagnostics (OBD)
No new posts AC Running with Recirculation Below +2°C? Transmission, Chassis, Body & Interior
No new posts Automatic Transmission Sport Mode Retrofit for TDI 93 On-Board Diagnostics (OBD)
