Doku Luop 6X1 MJ 2002, Window regulators stiff (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post01-01-2003, 16:02    Subject: Doku Luop 6X1 MJ 2002, Window regulators stiff Quote
Window motor stiff
Windows do not close completely at speeds above 80 km/h.
Cause:
Due tolerances in the door frame allow for an imperfect fit of the window pane. As a result, the pane no longer engages with the upper window seal at speeds of 80 km/h or higher. Furthermore, there is a problem with the window regulator.
Solution:
Window operation - if necessary, widen the gap to ensure optimal disc lift.
If this does not achieve the desired result, then shims must be placed at the lower fixing points of the window regulator mechanism so that the blade continues to move further inwards at the top.
Tschüss
Michael II
Ratings - Doku Luop 6X1 MJ 2002, Window regulators stiff
No new posts Document A2 8Z0 MJ 2002, Window lifter not functioning Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A3, from 05/03, Seat lengthwise adjustment... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A4 8D bis 12/1999, Fensterheber fehlerhaft Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lenkung schwergängig? Transmission, Chassis, Body & Interior
No new posts Loading pressure too high, ASZ (likely referring to a spe... Upload
No new posts Is Lima's clutch always so difficult to engage? Diesel Engine Technology
No new posts Rear brake caliper, rear brake lever mechanism, stiff Transmission, Chassis, Body & Interior
