3C: Softtouch does not work
Post09-04-2008, 16:21    Subject: 3C: Softtouch does not work Quote
I would like the rear door to open in the same way as the grill over the license plate, when I pull the switch in the door or hold down the middle FFB button.
Unfortunately, whether I use Softtouch or not makes no difference:
Address 46: Comfort System Label file: RKS\3C0-959-433-46.LBL
Part Number SW: 3C0 959 433 R HW: 3C0 959 433 R
Part Number: KSG PQ46 ELV 042 0472
Encoding: 0091020051034E763002941570084F0E707C00
Workshop #: WSC 05311
Part Number: 1K0 951 605 D
Part: LIN BACKUP HORN H07 8003
Component: NGS n.mounted
Component: IRUE n.mounted
No errors found.
No new posts A2 Doku: 8Z0 MJ 2003, Non-Functional Soft Touch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9, MJ 98/99, Motor geht aus, Fehlercode 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts The pre-heating lamp is not turning off. Motor does not s... Diesel Engine Technology
No new posts Diodentrick geht nicht Diesel Engine Technology
