Audi A6 Injector: Replacement & Repair Guide
chli1976
Karma: +185 / -0   Thank you, like it!
Post07-04-2008, 20:40    Subject: Audi A6 Injector: Replacement & Repair Guide Quote
My acquaintance has an Audi A6 2.5 TDI with engine code AKE.
The error log indicates a problem with the needle lift sensor. (I don't have the exact error code at hand right now). In any case, this sensor should have a resistance between 90 and 140 ohms, but it is currently measuring 340 ohms.
You can't tell from the engine's running that the injection timing might be incorrect. In diagnostic data block 4, the "actual" value shows 0.0°. Could it be that the control unit is switching to a limp-home mode?
I can't say how long he's been driving like that, because you wouldn't notice anything indicating whether the engine is running harder or softer.
Translated on 02-08-2026, 10:27.
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post07-04-2008, 23:12    Subject: Audi A6 Injector: Replacement & Repair Guide Quote
Welcome to the club of broken NHGs.
No, it doesn't go into emergency mode because, as you already noted, it doesn't significantly affect the engine power. The injection timing is controlled by the ESP control unit, and logically, it's no longer quite as precise.
However, the increased consumption can be up to one liter.
The cost is €450 from Bosch, and €490 from the Audi partner (excluding installation).
Translated on 02-08-2026, 10:29.
christians
Post08-04-2008, 12:33    Subject: Audi A6 Injector: Replacement & Repair Guide Quote
Opel and Ford omitted the NHG (presumably a specific component or feature) from engines equipped with the VP44 fuel injection system.
Gruß Christian
Translated on 02-08-2026, 10:30.
chli1976
Post11-04-2008, 22:41    Subject: Audi A6 Injector: Replacement & Repair Guide Quote
I installed a new needle lifter today.
I only noticed in measurement block 4, under the basic settings, that when switching to...
The duty cycle gradually increases from approximately 70% to 100%, but the injection timing remains unchanged.
I've never paid this much attention to whether this is the same for other V6 engines; I've always only looked more closely at the MWB 3.
Shouldn't the duty cycle normally be at 100% immediately when switching?
late?
Translated on 02-08-2026, 10:31.
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Needle driver On-Board Diagnostics (OBD)
No new posts Needle Valve: Types, Function & Applications Diesel Engine Technology
No new posts 1Z Needle Valve Actuator in ASV ??? Diesel Engine Technology
No new posts Nadelhubgeber Diesel Engine Technology
