LaurenzBo Blaumann
Joined: 03/02/2007 Posts: 52 Karma: +6 / -0 Location: Erlangen
25-04-2008, 8:19 Subject: G3 GTD Driveshaft Vibration Dampener (AAZ) |
"On my Golf 3 GTD Variant, manufactured in 1994, the vibration damper on the right driveshaft (not the one located under the pulley) is loose. Is it possible to replace just the damper disc, or does the entire driveshaft need to be replaced?"
Translated on 18-10-2026, 4:26.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
25-04-2008, 8:41 Subject: G3 GTD Driveshaft Vibration Dampener (AAZ) |
I don't know.
"But I would try to glue it in place using two components of adhesive."
Can we move that aside?
Stick it in place, then reattach it to the same spot, and secure it - you're done. Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 18-10-2026, 4:27.
Profile PM Email Garage |
efistho Blaumann
Joined: 03/10/2008 Posts: 135 Karma: +1 / -0 Location: Wolfsburg
25-04-2008, 12:24 Subject: G3 GTD Driveshaft Vibration Dampener (AAZ) |
The damper was also available as a separate item!
Translated on 18-10-2026, 4:28.
germa Blaumann
1993 Volkswagen Passat Free account, no CAN development support
25-04-2008, 21:21 Subject: G3 GTD Driveshaft Vibration Dampener (AAZ) |
You can also completely remove the damper and continue without it.
VW states that older models can also be driven without it.
Profile PM Garage |
LaurenzBo Blaumann
26-04-2008, 13:24 Subject: G3 GTD Driveshaft Vibration Dampener (AAZ) |
Thanks for the tips, I'll give the adhesive a try. The minimal effort makes it worth experimenting with.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1514 Karma: +649 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
12-05-2008, 16:08 Subject: G3 GTD Driveshaft Vibration Dampener (AAZ) |
LaurenzBo wrote: | | Thank you for the tips, I'll try the glue. The minimal effort is worth the attempt. |
Hi.
I always used to cut them off, and I never had any problems.
Best regards, Rüdi. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 18-10-2026, 4:29.
Profile PM Garage |
