Golf 4 Clutch Slipping - 81kW Fix (Solution)
TDI Thomas
Post27-12-2002, 19:22    Subject: Golf 4 Clutch Slipping - 81kW Fix Quote
Hello everyone,
'Recently, a diesel line broke on my Golf, and it...'
A large amount of diesel has spread throughout the engine compartment. I was taken to the nearest VW dealership.
My car was towed to the workshop. Today, I picked up my vehicle. The mechanic already pointed out a slipping clutch to me, but advised me to...
'If it doesn't work, we'll just have to put in a new clutch!'
Now, my question to you: Does a new clutch really need to be installed now?
'Or is there an old 'home remedy' like brake cleaner or engine cleaner, or does none of that really work 100%?'
'If a new one needs to be installed, what's the cost?' (The person being quoted said...)
Master: 'Not for less than €1000!'
Can I also go to ATU?
We would be very grateful for some quick and helpful answers.
Thomas
Translated on 29-10-2026, 5:33.
Michael B
Post27-12-2002, 20:21    Subject: Golf 4 Clutch Slipping - 81kW Fix Quote
Hi Thomas,
That's a really stupid thing!
I probably also hoped that the diesel fuel would evaporate when the clutch was slipping.
No idea - if you try it for a longer time???
Otherwise, all you can do is remove the gearbox and try to clean the lining with brake cleaner.
I stepped in a puddle of diesel just yesterday while filling up the car, and then the pedals were really slippery.
I definitely wouldn't leave 1000 euros with VW.
ATU or other independent workshops can do just as well.
Besides the tightening torques, there's nothing else they don't know.
Michael.
Translated on 29-10-2026, 5:35.
TDI Thomas
Post27-12-2002, 21:10    Subject: Golf 4 Clutch Slipping - 81kW Fix Quote
Hi Michael,
Yes, it's really annoying - Merry Christmas.
I was thinking about pouring brake cleaner into the opening in the transmission (above the clutch) – basically, really soaking it. But I'm not sure if that would actually do anything.
But thank you in advance.
Translated on 29-10-2026, 5:37.
Karma: +807 / -0   Thank you, like it!
Post27-12-2002, 21:59    Subject: Golf 4 Clutch Slipping - 81kW Fix Quote
Hello Thomas,
If I were you, I would try spraying about a liter of brake cleaner through the inspection hole of the clutch bell, while the engine is off and the clutch pedal is depressed.
Given the significant fire risk associated with this procedure, the engine should be cold and turned off, and it is best to perform the action outdoors.
Once you've already removed the transmission, it's a good idea to have a new clutch installed at the same time, as the majority of the cost associated with a clutch replacement is labor.
Translated on 29-10-2026, 5:38.
TDI Thomas
Post28-12-2002, 8:38    Subject: Golf 4 Clutch Slipping - 81kW Fix Quote
Hello Rainer,
Yes, I think so too. Since I don't have much to lose with the clutch, I'm going to start 'brake cleaner' operation this morning.
My problem will be the atomization of the cleaner (I don't have the necessary equipment - a spray gun). But maybe the spray nozzle of the can will be sufficient. icon_confused.gif
I'll let you know later if that made any difference.
Thomas
Translated on 29-10-2026, 5:39.
TDI Thomas
Post01-01-2003, 17:47    Subject: Golf 4 Clutch Slipping - 81kW Fix Quote
To all of you, and a happy new year.
I just wanted to let you know that my clutch is working perfectly again. icon_biggrin.gif
I alternately poured motor cleaner and then brake cleaner into the 'OT hole,' a total of 4 times. The engine was running, and a second person continuously operated the clutch (all while the engine was cold).
Thomas
Translated on 29-10-2026, 5:40.
Post01-01-2003, 19:38    Subject: Golf 4 Clutch Slipping - 81kW Fix Quote
TDI Thomas wrote:
Just wanted to let you know that my clutch is working perfectly again. icon_biggrin.gif
I alternately poured motor cleaner and then brake cleaner into the "OT hole," a total of 4 times.
The engine was running, and a second person was constantly operating the clutch (all while the engine was cold). icon_biggrin.gif
Hi Thomas,
Thank you for the final report and success report }.
@Rainer: If this isn't already in the error database, I think it's worth adding an entry.
Translated on 29-10-2026, 5:41.
Post01-01-2003, 20:46    Subject: Golf 4 Clutch Slipping - 81kW Fix Quote
Hi Thomas, congratulations on your bonus kilometers! I just remembered something: timing belts don't like oil. If the timing belt also got some oil on it, I would recommend replacing it as a precaution.
@ Ulf: I'm moving the thread.
Translated on 29-10-2026, 5:42.
Ratings - Golf 4 Clutch Slipping - 81kW Fix
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop action: Free-running disc, Sharan 81kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Slipping Golf 4 TDI ALH - Fix It! Diesel Engine Technology
No new posts Clutch slipping after chip tuning (90hp) on a VW Golf IV ALH Diesel Engine Technology
No new posts Clutch slipping on ASZ engine Diesel Engine Technology
No new posts Clutch Slipping? Get Help Now! Diesel Engine Technology
