RS TDI Guest
10-11-2007, 18:48 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
BPX in Ibiza, likely with over 200 horsepower.
Last winter, I installed a Sachs Race clutch because the original one was slipping.
Slipping is now gone.
'At around 2200 RPM, it makes a rubbing noise, which is probably the ZMS (dual-mass flywheel).'
I was wondering if there's a conversion kit available for a single-mass flywheel.
Can the original ZMS be reworked?
Best regards.
RS TDI Guest
11-11-2007, 10:25 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
Today, I received the following as a private message:
'My tuner has something like that.'
From Spec.
That's an aluminum single-mass flywheel, and I hope you're aware of the negative consequences of such a modification.
If you are interested, feel free to contact me;-).
Alexander
PS: Since I'm not yet a 'Blaumann' in the forum, I have to send you this via private message.'
What negative consequences can be expected?
'Of course, some comfort will be lost because the dual-mass flywheel (ZMS) absorbs and thus dampens vibrations.'
It should still be drivable, right???
Has anyone had any experience with this?
Best regards.
3 Phasen Biber Blaumann
2001 Volkswagen Golf Free account, no CAN development support
11-11-2007, 14:42 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
What is this supposed to achieve?
The ZMS absorbs the energy. If you replace it with a normal flywheel (assuming that's even possible!), then there's nothing left to absorb the energy and dampen the vibrations!
ehemals G4 ASZ, jetzt G4 ARL
Profile PM Garage |
Aron Blaumann
Joined: 10/26/2006 Posts: 440 Karma: +5 / -1 Location: KC
11-11-2007, 17:39 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
3 Phasen Biber wrote: |
The ZMS absorbs the energy. If you replace it with a normal flywheel (assuming that's even possible?!), then there's nothing left to absorb the energy and dampen the vibrations! |
The question is, when will the transmissions and drives fail, and also, the clutch will be subjected to greater stress. The first question would be: what is the torque curve of the vehicle? Is there a significant torque peak at 2000 rpm, which then decreases slightly until 3000 rpm? I would start by looking at that.
RS TDI Guest
11-11-2007, 22:26 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
Is that really so bad? (regarding vibrations, etc.)
Are there any known best practices or experiences related to this?
'Many people also use the AFN to switch from the 1z EMS.'
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
11-11-2007, 22:30 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
I had a customer's vehicle with EMS on the ARL, and it was rattling like crazy at idle. I think there was something loose with the clutch, because when you pressed the clutch pedal, the rattling stopped (but it still vibrated a lot).
Profile PM WWW Garage |
Stefan-TDI Blaumann
Joined: 08/26/2007 Posts: 85 Karma: +1 / -0 Location: Bodensee 1997 Volkswagen Golf Free account, no CAN development support
11-11-2007, 22:58 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
The problem is the uneven acceleration of the flywheel; with each ignition, the flywheel spins faster than it does just before the next injection. These "voltage spikes" cause, on the one hand, loud noises, and on the other hand, increased stress on everything that comes after the crankshaft.
However, I can't tell you whether your transmission will fail after 5,000 km or 100,000 km, but it will likely fail sooner than with a dual-mass flywheel.
Profile PM Garage |
RS TDI Guest
12-11-2007, 9:19 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
Hmmm, sh...
What can you recommend?
A new ZMS (Zentrale Materialwirtschaftssystem) is definitely 'AFFORDABLE'.
Is there anything with extra strength available?
Best regards.
12-11-2007, 16:48 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
I am not aware of anything like that! What exactly are you trying to emphasize about it? The feather package?
Profile PM Garage |
RS TDI Guest
22-11-2007, 17:50 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
Is the use of a ZMS (Zentrale Materialstammdaten – Central Material Master Data) mandatory only for PDs (Produktdefinitionen – Product Definitions)?
The 1Z and lower levels didn't have that kind of stuff, did they  ?
Jochen_145 Guest
22-11-2007, 17:58 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
The 1Z engines, unlike the 'modern' TDI engines, also ran like garbage.
The curved wave element is adapted to the ZMS, meaning that if the system is converted to an EMS, the element will no longer fit.
Furthermore, the smoother operation of the transmission input shafts makes the gearbox significantly more robust than it would be otherwise. Only in this way can 350 Nm of torque be continuously withstood.
So, you already have two reasons why the 1Z model could function without a ZMS (Zero Mass System).
Best regards, Jochen.
22-11-2007, 18:14 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
@ RS TDI
You wouldn't compare a 1Z engine to a modern PD-TDI, would you?
Just take a look at the torque values!
Profile PM Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
22-11-2007, 18:25 Subject: Fingerprint recognition |
Logically, there should be factory-adjusted springs or ZMS (Zahnmodulkupplung) for the various torque loads; otherwise, the ZMS will always fail on the spring block  when overloaded.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
RS TDI Guest
22-11-2007, 20:38 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
And what should I do now???
The 'OLD' zms is probably broken.
Install the new part and then what???
Held467 Blaumann
22-11-2007, 20:44 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
Getting a decent chip would be a good idea, right?
cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
23-11-2007, 10:08 Subject: BPX dual-mass flywheel - conversion kit available for single-mass |
At AFN, they are also transitioning to EMS (Electric Mobility Systems), and some of their products have a significant amount of torque.
You just need to make sure to install a sprung clutch. And if you install everything correctly, the engine will run properly.
