Leave the interface permanently connected?
Post18-06-2008, 11:49    Subject: Leave the interface permanently connected? Quote
Hello.
Can a CAN<->USB interface be permanently connected to the vehicle?
I can imagine that not all ECUs would go into a sleep mode, and the battery could drain quickly as a result.
I'm envisioning a conveniently accessible USB port in the center console – instead of having to awkwardly maneuver that bulky OBD connector over the footwell trim.
Translated on 16-07-2026, 9:16.
Uwe@Ross-Tech
Post22-06-2008, 15:30    Subject: Leave the interface permanently connected? Quote
If no data is flowing from the PC through the interface, it should not have any influence on whether or how quickly the control units go into sleep mode.
However: The interface draws power from pin 16, which is connected to terminal 30. Therefore, as long as it remains plugged in, it will draw current. A few hours or even overnight is not a problem, but if left plugged in for too long, it could drain the battery.
If you really want to connect it permanently, it might be a good idea to modify the power supply to use terminal 15. I would create a second OBD socket that is electrically connected in parallel with the original socket (except for the power supply).
-Uwe-
Translated on 16-07-2026, 9:17.
klopfer
2007 Audi A4 Avant
Post22-06-2008, 19:40    Subject: Leave the interface permanently connected? Quote
I once had a permanent USB cable running into the interior of the car. The connectors weren't plugged in by default, so whenever I wanted to read out some data, I would simply open the hood and plug in the connectors.
Best regards.
knocker
Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
Translated on 16-07-2026, 9:18.
No new posts Lupo Door Problems: 6X1 MJ 2002 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor Golf 4: Location & Installation On-Board Diagnostics (OBD)
No new posts Permanently disable WFS Diesel Engine Technology
No new posts ESP light is constantly on. Diesel Engine Technology
No new posts 3.0 TDI CDYA - AGR valve stuck open at 99.6% + RPM fluctu... On-Board Diagnostics (OBD)
