wobedi32
01-04-2007, 17:59 Subject: Can You Determine Engine Mileage? |
Hello!!
I need some urgent advice. I recently bought a used 1.9 1Z TDI engine that is supposedly supposed to have 127,000 km on it.
But somehow, I have a feeling that this one is more capable.
Is there a way to verify if this is true?
I would be very grateful if you could provide me with some information on that matter.
Best regards, Wobedi32.
Translated on 29-07-2026, 9:10.
Bastelfred Blaumann
Joined: 01/09/2004 Posts: 51 Karma: +6 / -4 Location: bei Schwerin
01-04-2007, 19:21 Subject: Can You Determine Engine Mileage? |
Impossible, and for good reason.
mullemaus Guest
01-04-2007, 20:49 Subject: Can You Determine Engine Mileage? |
In the 'newer' models, it's configured in the engine control unit. In this 'older' one, there's less of that  . All you can do is have faith, and faith can move mountains  .
Translated on 29-07-2026, 9:11.
Torfhausracer
26-04-2007, 19:59 Subject: Can You Determine Engine Mileage? |
Apparently, there are ways to determine the mileage from the engine oil. This usually costs around €100. Just ask at DEKRA.
matthiasTDI96 Profi-Schrauber
26-04-2007, 20:51 Subject: Can You Determine Engine Mileage? |
"Yes, great tip... and if that doesn't work, you can also read the coffee grounds; you can even imagine the decimal places there! ... After an oil analysis, you only know which engine wear particles are floating around in it."
Translated on 29-07-2026, 9:12.
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
26-04-2007, 20:58 Subject: Can You Determine Engine Mileage? |
He probably means the mileage of the engine oil.
Otherwise, perhaps it might be possible to determine how many children someone has  through a sperm sample.
3B5 AJM
rubberduck Blaumann
26-04-2007, 21:06 Subject: Can You Determine Engine Mileage? |
Well, my engine and car didn't seem to have suffered from the extra 100,000 km. According to the odometer, mine should have had 170,000 km on it. Since I didn't trust that Southern European car dealer, I did some research and found information in the VW database. The vehicle was last at a VW workshop six months before the purchase with a mileage of around 260,000 km. Maybe that's a way to find out something if you can get the VIN from the donor vehicle. Otherwise, maybe go to a fair and visit the nice lady with the crystal ball  .
Wer Rechtschreibfehler findet, kann sie behalten !
Translated on 29-07-2026, 9:13.
Torfhausracer
30-04-2007, 20:51 Subject: Can You Determine Engine Mileage? |
To be honest, I can't really imagine exactly how the engine oil analysis is performed, but it is recognized as an expert opinion in court. It is also possible to carry out the analysis even after several oil changes, provided that the oil being tested has been running in the engine for 1000 km.
Translated on 29-07-2026, 9:14.
doppelteglasur Guest
10-05-2007, 17:15 Subject: Can You Determine Engine Mileage? |
Here's an analysis of a diesel engine oil, along with the report.
http://www.wearcheck.de/images/pdf/laborberichte/dieselmotor.pdf
Translated on 29-07-2026, 9:15.
Torfhausracer
10-05-2007, 18:14 Subject: Can You Determine Engine Mileage? |
Has the kilometer reading on the document been read or verified? What is the exact cost? And where can I have this done?
Thank you in advance.
tdi-schrauber Blaumann
10-05-2007, 19:21 Subject: Engine Mileage: How to Check & Find Out |
Hello!
wobedi32 wrote: |
Is there a way to determine if this is true? |
Break down...
Everything else is uncertain...
- new engine with existing control unit.
- or vice versa.
- or, or, or
BYE
TDI mechanics.
Translated on 29-07-2026, 9:16.
10-05-2007, 21:13 Subject: Can You Determine Engine Mileage? |
@torfhausracer
You can have it done at www.wearcheck.de.
Prices vary depending on the scope of work and type of engine. For a diesel engine, it's approximately €60.
'You can't determine the KM values like that; I think the information was read from somewhere.'
This test is actually intended for large equipment, where an oil change can sometimes cost several thousand euros.
costs.
In my opinion, this type of test is much more informative than any mileage reading.
It is possible to quite reliably determine which bearing or component is experiencing wear by analyzing increased metal content (as described in the report).
Translated on 29-07-2026, 9:18.
Torfhausracer
11-05-2007, 18:07 Subject: Can You Determine Engine Mileage? |
"Thank you very much. I'm currently having a problem where the mileage on my car has been tampered with. Unfortunately, there is no mileage information stored in my car's MSG (Airbag Control Unit), or perhaps the EEPROM chip has simply been removed."
Translated on 29-07-2026, 9:19.
mullemaus Guest
11-05-2007, 18:21 Subject: Can You Determine Engine Mileage? |
Thank you very much, I'm currently having the problem that my mileage has been tampered with. But unfortunately, there is no mileage information stored in my MSG (ALH), or perhaps the EEPROM was simply removed...
In the same place are the data for the immobilizer system. It's unlikely that anyone would intentionally remove the EEPROM.
Translated on 29-07-2026, 9:20.
Torfhausracer
11-05-2007, 18:49 Subject: Can You Determine Engine Mileage? |
"I was informed about this by a Bosch service center. Unfortunately, I don't know much about the subject myself, but I always appreciate tips and advice. Is the mileage also stored in the ABS system?"
Translated on 29-07-2026, 9:21.
mullemaus Guest
11-05-2007, 19:01 Subject: Can You Determine Engine Mileage? |
More or less yes. But it needs to be converted first.
