Zahnriemenwechsel beim A6?
RomanA6
Post22-12-2002, 16:00    Subject: Zahnriemenwechsel beim A6? Quote
Hi everyone!
Has anyone ever replaced the timing belt on the AFB engine themselves?
Does one also manage without the special tool or can one help oneself in another way?
For the 4-cylinder TDI, you can find the diagram of the fuel pump here. Does anyone have the diagram for the AFB V6?
Best regards.
Novel
GarfieldMZ
Post22-12-2002, 20:46    Subject: What kind of chart do you have in mind? Quote
Hello Roman!
Are you referring to the complete instructions for the replacement, or the diagram for checking the dynamic injection start?
DENNIS
RomanA6
Post22-12-2002, 20:56    Subject: Zahnriemenwechsel beim A6? Quote
Instructions for the change are available. Do you have the diagram?
Have you ever done it?
Best regards.
RomanA6
GarfieldMZ
Post22-12-2002, 21:00    Subject: No diagram! But... Quote
Hello Roman!
So, zunächst einmal, ich habe bisher nicht den Mut gehabt, beim AFB die Riemen zu wechseln. The effort seems considerable...
A diagram similar to the one in the 1Z doesn't seem to exist, at least not to my knowledge. However, I have a guide for checking the dynamic injection timing. If you wish, I can send them to you by email!
DENNIS
Michael II
Post22-12-2002, 21:33    Subject: Zahnriemenwechsel beim A6? Quote
Audi specifies the following special tool:
Special Order Part T40011
Countermeasure 3036
3242 Fixing Screw
Marking tool 3359
Camshaft retainers 3458
Without proper guidance, I wouldn't dare to do that.
Tschüss
Michael II
RomanA6
Post25-12-2002, 18:12    Subject: Zahnriemenwechsel beim A6? Quote
hey everyone!
The tools themselves aren't really a problem, except for the following:
3242 Fixing Screw
Does anyone know if there's another way to get help?
Best regards.
roman
oldtimerdane
Post08-01-2003, 22:49    Subject: Timing belt replacement A6 AFB Quote
Fix Screw 3242: Could someone possibly manufacture this on my lathe for a small fee, if they have the exact dimensions? Ideally, a technical drawing with the exact dimensions would be best. For increased interest, please email: [email protected]
If multiple interested parties inquire, I will also take care of the measurements.
haehnlein
Post08-01-2003, 22:53    Subject: Zahnriemenwechsel beim A6? Quote
RomanA6 wrote:
3242 Fixing Screw
These tools can be found at www.matra.de.
Christian
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Doku Fehler beim Zahnriemenwechsel, AGP,AGR,AHF,ALH u.a Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Timing Belt Replacement for AEL Engines Diesel Engine Technology
No new posts Zahnriemenwechsel beim AJM Motor Diesel Engine Technology
No new posts Zahnriemenwechsel beim passat 3b 98 Diesel Engine Technology
No new posts Timing belt replacement interval for AHF-TDI engines Diesel Engine Technology
