Log File Analysis: Review Request
zed
Registered VCDS User
Post01-07-2008, 11:51    Subject: Log File Analysis: Review Request Quote
Hello everyone,
I've been a long-time reader of this forum and have often been able to find solutions by searching. Now, I'm facing a problem where I need your help.
Vehicle: VW Golf 4, model year 2000, ALH 90 hp engine, mileage 183,000 km. Chip tuning by B&B to 105 hp at 70,000 km. No issues except for a faulty dual-mass flywheel. Mass airflow sensor (MAF) replaced at 100,000 km.
Problem: Very slow boost build-up, only reaching boost at approximately 2100 RPM. Perceived power loss of about 20% across the entire RPM range (acceleration without any noticeable "holes"). No mechanical noises detected, no audible air leaks, and the error memory is clear.
The log file is located in the upload area.
Thank you in advance.
Best regards from the Westerwald region.
Maurice.
Translated on 05-10-2026, 15:28.
zed
Post01-07-2008, 18:40    Subject: Log File Analysis: Review Request Quote
UPDATE:
Error found: The turbocharger is defective. While the variable geometry turbine (VGT) valve still moves freely, but...
The wave becomes difficult to turn after a few rotations.
Best regards, Maurice.
Translated on 05-10-2026, 15:30.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts MWB 3 & 11 MKB ASZ: Evaluation/Review On-Board Diagnostics (OBD)
No new posts Engine Misfire: Get a Professional Diagnosis On-Board Diagnostics (OBD)
No new posts Chip Tuning: Yes or No? (MWB 3-8-11) On-Board Diagnostics (OBD)
No new posts Unlikely Signal 16485-LMM: Log File Analysis Needed On-Board Diagnostics (OBD)
