Oily intake manifold
dokky
2013 Volkswagen Golf
Post17-07-2008, 13:37    Subject: Oily intake manifold Quote
"I've noticed an increasing amount of knocking during engine operation in my 1.9 MJet 16V. It also vibrates slightly under full load. Because I've detected a diesel smell in the last few days, shortly after turning off the engine, I removed the cover today and took a look." I could not detect any fuel leaks, however, the intake manifold is coated with oil mist on two cylinders near the common rail pump.
Should I have that checked out? Maybe a valve isn't working properly? Or is oil mist after 15,000 km normal?
dokky
Post29-07-2008, 13:55    Subject: Oily intake manifold Quote
Error found. A pipeline was leaking under full load. Now he's purring again.
No new posts AEL - Timing belt oily Diesel Engine Technology
No new posts Intake Manifold Questions: Details & FAQs Diesel Engine Technology
No new posts KKK Turbo with intake manifold on AFN Diesel Engine Technology
No new posts Intake Manifold for 96kW PD Engine Diesel Engine Technology
