Audi 80 TDI AC: Climate Control for 93 Models
80_b4_tdi
Post02-08-2008, 10:33    Subject: Audi 80 TDI AC: Climate Control for 93 Models Quote
Hello everyone,
I'm having a problem with my air conditioning.
Okay, so it's a manual air conditioning system. When I turn it on, the compressor engages and it noticeably gets cooler.
Eventually, it starts happening, and you notice a distinct jerking during driving, approximately every 10-20 seconds. It didn't do that before.
Man hört ein deutliches schalten einen Relais oder Schalter aus dem Beifahrer-Fußraum, dann schaltet kurz drauf ein Relais im Fahrer-Fußraum, der Kompressor schaltet sich zu….und es ruckt….und Sekunden später, es klackt wieder im Beifahrer-Fußraum und die Magnetkupplung schaltet den Kompressor wieder ab. Und das Always going in circles...
Can someone perhaps tell me something about that...?
The system was last filled with fluid about two years ago.
I read something about a pressure switch here. Does anyone know where it's located?
Greetings.
Audi 80 B4
Bj. 1993
1,9TDI mit 90PS
370000 Km auf der Uhr.
Translated on 06-10-2026, 8:45.
Back to top Profile PM Email
wolfi_b
Post04-08-2008, 10:34    Subject: Audi 80 TDI AC: Climate Control for 93 Models Quote
I suspect that the air conditioning system is being repeatedly turned off and on by the low-pressure switch due to a refrigerant leak.
Oh yeah: your manual climate control system is diagnosable, so you can easily check it.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 06-10-2026, 8:46.
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Air conditioner smells bad General Tips
No new posts Empty the air conditioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 AC Leak: Repair & Troubleshooting Transmission, Chassis, Body & Interior
No new posts Power supply for Audi A4 B5 air conditioning Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A3 AC Not Working: 8P BKD Repair Guide Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) Transmission, Chassis, Body & Interior
