godot Guest
29-12-2002, 0:14 Subject: VP44 Injector Pump Replacement |
I https://community.dieselschrauber.org/en/viewtopic.php?t=1746) purchased a new fuel injection pump for my AFB (in a Passat 3B, 100,000 km, see } on eBay) for EUR 430 instead of EUR 1500. It supposedly came from a workshop clearance sale, is in like-new condition, has not been installed, and has been checked by a Bosch service. The seller presented all of this in a fairly convincing manner.
'Silly question (I'm not an expert, I work in IT): If I have this part installed at my VW/Audi workshop, how do they know how the gear on the pump's drive shaft needs to be positioned when they install the timing belt?'
Thank you in advance.
Christian.
Translated on 16-10-2026, 20:12.
Lanz Guest
29-12-2002, 10:57 Subject: VP44: Common Rail Injector Problems & Solutions |
However, your title indicates that you acquired a VP44 pump. If that's the case, you might have gotten a bargain, but the pump won't fit in your car. Within the Volkswagen Group, the Audi V-6 engine is the only model that has ever been equipped with such a pump.
Best regards, Lanz.
Translated on 16-10-2026, 20:13.
29-12-2002, 11:31 Subject: VP44 Injector Pump Replacement |
If I'm not mistaken, the V6-TDI engine was also available in the Passat 3B, and the specified engine code likely corresponds to the V6 model.
But on a completely different note... if the ESP system fails after 100,000 km, wouldn't that almost qualify for warranty coverage? It should really last much longer.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 16-10-2026, 20:14.
Lanz Guest
29-12-2002, 12:20 Subject: VP 44: A Deep Dive into the Details |
You're right, Jan. The same V6 engine was also briefly installed in the Passat. It had 110 kW and a 2.5-liter displacement. The engine codes were AFB and AKN. Sorry, I had overlooked that.
Best regards, Lanz.
Translated on 16-10-2026, 20:15.
diesel.gustav Guest
30-12-2002, 19:23 Subject: VP44: Disconnecting for Installation - Guide |
Deleted upon request.
Translated on 16-10-2026, 20:16.
oldtimerdane Guest
08-01-2003, 21:41 Subject: VP44 Diesel Injection Pump |
If someone accidentally or unknowingly loosens the fuel injection pump rotor, or if they don't want to pay the friendly price of €1600 for the repair, I might be able to help.
Having personally experienced problems with the VP44 fuel injection pump (A6 engine KB:AFB with 240,000 km), I have extensively researched this topic.
mailto: [email protected]
