VCDS TDI Timing: No 1Z Support
kossmann
2016 Audi Q3
Post23-07-2008, 10:10    Subject: VCDS TDI Timing: No 1Z Support Quote
Hello everyone,
Could it be that in the new VCDS version (by Rainer), when selecting "TDI Timing," only the engine variants "AGR, AHF, ALH, ASV" are available? The dropdown menu only shows this one option. I'm missing the older 1Z variants – specifically, the ones for my 1Z.
I have readings of "t Diesel = 149" and "SB = 23" - according to the graph, this is too late (significantly below the lower line). Now I'm not sure if this is due to the wrong engine variant and whether these values are acceptable for the 1Z engine, or if I actually need to make some changes.
Translated on 15-08-2026, 23:33.
Post23-07-2008, 10:56    Subject: VCDS TDI Timing: No 1Z Support Quote
Here's the graph from a 704.1.
 Bug TDIGraph
 File size:  141.98 KB
 Viewed:  2442 times
Translated on 15-08-2026, 23:34.
Uwe@Ross-Tech
Post24-07-2008, 4:25    Subject: VCDS TDI Timing: Troubleshooting & Solutions Quote
Hello everyone,
Could it be that in the new VCDS version (by Rainer), when selecting 'TDI Timing,' only the engine variants 'AGR, AHF, ALH, ASV' can be chosen? The dropdown menu only has this one option. I'm missing the older 1Z variants - or the ones specifically for my 1Z.
Do you use the current data as of June 26, 2008?
'With that in mind, the selection should actually look like this:'
http://www.Ross-Tech.net/vag-com/screen-shots/TDIGraph_Selection.png
We have reorganized the engine variants to make them more organized overall and to avoid redundant entries.
-Uwe-
Translated on 15-08-2026, 23:35.
kossmann
2016 Audi Q3
Post24-07-2008, 9:34    Subject: VCDS TDI Timing: No 1Z Support Quote
Hello Uwe,
How can I tell which version of the data is installed, and where can I download a corresponding file? Where should I put this file? I downloaded the complete installation from Rainer's shop a few weeks ago.
When I click on the dropdown menu – or the arrow next to it – nothing happens; no engine options appear.
Translated on 15-08-2026, 23:36.
vagtuning
Post24-07-2008, 13:28    Subject: VCDS TDI Timing: No 1Z Support Quote
VCDS > ABOUT, and then at the top, below the version number, you'll find the data status.
Translated on 15-08-2026, 23:37.
kossmann
2016 Audi Q3
Post24-07-2008, 18:31    Subject: VCDS TDI Timing: No 1Z Support Quote
I have the version dated 20080612 – if I understand Uwe correctly, it's not the most recent one.
Rainer... did you forget something in your version, or am I missing something?
Post24-07-2008, 19:02    Subject: VCDS TDI Timing: No 1Z Support Quote
Hi Tino,
Why not simply download the latest version and check if the problem has been resolved?
Translated on 15-08-2026, 23:38.
kossmann
2016 Audi Q3
Post24-07-2008, 22:25    Subject: VCDS TDI Timing: No 1Z Support Quote
I just uninstalled, downloaded a fresh copy, and installed it... and at least the data version is now 20080626. Since I'm currently on vacation in Austria, I won't be able to test this until my return trip (on Saturday), and I'll let you know then. It seems like that was the cause of the problem.
Best regards and thank you!
Translated on 15-08-2026, 23:39.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS TDI Timing: RT & RKS Configuration On-Board Diagnostics (OBD)
No new posts AFN is annoyed: TDI timing? On-Board Diagnostics (OBD)
No new posts Fehlbedienung TDI Timing Checker On-Board Diagnostics (OBD)
No new posts TDI Graph: Analyze & Optimize Engine Timing On-Board Diagnostics (OBD)
