moby Guest
31-07-2008, 19:37 Subject: ASZ Engine: Whistling Noise After Shut Off |
Hello.
'I almost always hear a high-pitched whistling sound, twice in a row, coming from the engine compartment about a minute after I turn off the engine. The whistling sound gets progressively higher in pitch over the 4 seconds it lasts, and it starts quite quietly. There's a pause of about 2 seconds between the two whistling sounds, and both sounds are identical. I haven't been able to pinpoint the source of the noise after three attempts. Where could this noise be coming from? Could it indicate a leak in a hose, from which pressure is escaping when the car is stationary?'
cu moby
Translated on 26-09-2026, 15:59.
matthiasTDI96 Profi-Schrauber
01-08-2008, 7:23 Subject: ASZ Engine: Whistling Noise After Shut Off |
When the car is off, there's only vacuum left... so it could be a vacuum valve that's switching. I only hear it when the parking brake lever is released, but that sound stops about 10 seconds after the engine is turned off.
Translated on 26-09-2026, 16:00.
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
01-08-2008, 20:05 Subject: ASZ Engine: Whistling Noise After Shut Off |
Was the air conditioning on before you parked?
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
moby Guest
01-08-2008, 23:55 Subject: ASZ Engine: Whistling Noise After Shut Off |
haithamina
Hello, I'm just going to take them off now... it's not quite as warm anymore.
cu moby
Translated on 26-09-2026, 16:01.
