ABS Error Golf 4 SDI: Troubleshooting Guide
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
germa
1993 Volkswagen Passat
Post29-07-2008, 19:41    Subject: ABS Error Golf 4 SDI: Troubleshooting Guide Quote
Perhaps someone can help me or tell me what the underlying meaning of this error is, as I don't have any error descriptions for ABS.
Vehicle:
VW Golf 4 SDI, year of manufacture 1998, engine code: AGP, mileage: 172,000 km.
ABS:
Control unit number: 1J0 907 379 D.
ABS 20 IE CAN 0001
1 error.
00283 Front wheel speed sensor, left side (G47) 35-00---
The error occurred while driving; the warning light briefly illuminated and then, after hitting a bump, it has been constantly lit. Initially, the error was intermittent, but after I cleared it, it became permanent.
My father drove the vehicle. When he got home, he explained to me what had happened.
So far, I have only checked the connections at the plug, and everything seems to be okay.
Is it possible to check the ABS sensor using VAG-COM, and if so, what is the path to do so?
Best regards, Germa.
Infos zu meinem VW Passat Variant 35I mit Golf 4 TDI- Motor.
Guckst du einfach hier: https://community.dieselschrauber.de/garage.php?mode=view_vehicle&CID=63
Translated on 15-08-2026, 21:22.
Post30-07-2008, 8:20    Subject: ABS Error Golf 4 SDI: Troubleshooting Guide Quote
If you have VAG COM available, it's quite simple. You can read the speed for each wheel in the ABS control unit. If there's nothing displayed or something implausible for the front left wheel, check the connections to the connector, both where it passes through the wheel arch and at the ABS unit itself, and test for continuity. It's also possible that the sensor ring is dirty. Check that as well. If no fault can be found, the probability of a defective sensor increases significantly.
Translated on 15-08-2026, 21:25.
R.M.
Karma: +14 / -0   Thank you, like it!
Post30-07-2008, 12:47    Subject: ABS Error Golf 4 SDI: Troubleshooting Guide Quote
I also suspect a dirty sensor. I once had a similar problem after changing tires. Since the sensor is magnetic, it tends to collect rust from the brake disc. First, try removing it from its housing and cleaning it. If that doesn't work, check out Ulf's post.
Translated on 15-08-2026, 21:26.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post30-07-2008, 14:34    Subject: ABS Error Golf 4 SDI: Troubleshooting Guide Quote
Be careful when pulling it out; otherwise, it's guaranteed to be defective.
It's safer to compare the wheel rotation speeds when driving slowly – that way, you can tell if one of them has stopped rotating and is temporarily not displaying any information.
The old sensors on cars like the Sharan often fail because they corrode, and they can break when you try to remove them.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 15-08-2026, 21:27.
germa
Post01-08-2008, 12:40    Subject: ABS Error Golf 4 SDI: Troubleshooting Guide Quote
Thanks again for the information.
@matthiasTDI96Viewing profile: matthiasTDI96
I have an old VAG-COM version, but unfortunately, I can't find the option to check the ABS sensor. I've already checked the cable and it seems to be working fine.
@R.M.Viewing profile: R.M.
The ABS sensor is clean, but there's still an error.
@teileklausViewing profile: teileklaus
Yes, unfortunately, this is a known issue with Volkswagen vehicles where the ABS sensors break when they are removed.
The probability that the ABS sensor is defective is high. That's why I just bought a new ABS sensor for €10 on eBay (including shipping) and will try connecting it. If it's not the ABS sensor, I can afford to spend the €10 for the sensor; I'll just put it aside for later use. icon_smile.gif
Translated on 15-08-2026, 21:28.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post01-08-2008, 20:50    Subject: ABS Error Golf 4 SDI: Troubleshooting Guide Quote
and how do you know if it's good?
Translated on 15-08-2026, 21:30.
germa
Post01-08-2008, 22:22    Subject: ABS Error Golf 4 SDI: Troubleshooting Guide Quote
I'm assuming that a brand new sensor is in perfect working order!
P.S. This is not an original VW replacement part. (It costs approximately €50 at the official VW dealership).
germa
Post06-08-2008, 14:11    Subject: ABS Error Golf 4 SDI: Troubleshooting Guide Quote
Okay, the new ABS sensor is installed and the error is gone.
But taking the old one apart was a real pain.
The thing just wouldn't come out; it only did when I hit it with a hammer and it broke apart.
I used a file to remove the rust spots and then applied plenty of grease to prevent any further rusting.
Translated on 15-08-2026, 21:31.
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Problem with the ignition lock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J MJ 2001, Fehler 01435 im ABS-STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehler Golf III TDI AHU On-Board Diagnostics (OBD)
No new posts 7G-DSG Fehler bei Golf Plus Transmission, Chassis, Body & Interior
No new posts Golf IV 1.6 Fehler On-Board Diagnostics (OBD)
No new posts VW Golf IV: ESP/ABS error On-Board Diagnostics (OBD)
