Document A3, 8 liters, up to 2000, Error entry in the airbag control unit. (Solution)
Michael II
Post08-01-2003, 12:00    Subject: Document A3, 8 liters, up to 2000, Error entry in the airbag control unit. Quote
In the airbag control unit's memory, there is an entry: "Ignition for side airbag - resistance value too high". The error can be either intermittent or static.
Cause:
The yellow connector under the driver and passenger seats is contaminated due to the manufacturing process.
Solution:
The entire connector must be replaced, meaning the connector on the vehicle-side cable harness must be re-attached, and the side airbag module must be replaced, as the cable here cannot be repaired.
Important:
When performing these tasks, it is essential to maintain the highest possible level of cleanliness to prevent re-contamination of the connector.
Tschüss
Michael II
Ratings - Document A3, 8 liters, up to 2000, Error entry in the airbag control unit.
No new posts Airbag Error 65535: A3 8L Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Error 65535: A3 8L Fix (up to 8LYA078299) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Error 1317: Polo MJ 2001 Diagnostic Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag error code 00588 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Chip Tuning Error: What to Do? Diesel Engine Technology
No new posts EDC Error Entry: How Long Does It Take? Diesel Engine Technology
No new posts EPC without error entry On-Board Diagnostics (OBD)
