The sunroof does not close completely when using the "comfort close" function.
This applies only to models with a sliding sunroof and a central locking pump with a control unit.
Cause:
If the "comfort close" signal is interrupted during the closing process via the remote control, the sunroof cannot be closed again, even by pressing the close button on the remote key. However, the electric windows will still close completely.
An interruption can be caused by unintentionally releasing the lock button on the key fob or by an external disturbance to the radio signal.
The sunroof can only be reactivated by a process called a "reset," which involves pressing the open button and then immediately pressing the close button. This process resynchronizes the "comfort close" signal with the "unlock" signal in the central locking pump control unit.
The system is protected by a "tamper protection" feature. It allows only 20 consecutive signals (comfortable opening/closing) before locking itself. The system can then only be reactivated by turning the ignition on and off.
Solution:
To reactivate the "Comfort Close" function, press the "Open" button again, and then press the "Close" button again.
Tschüss
Michael II
Translated on 18-10-2026, 22:16.
