Audi A3 Door Auto Open/Close Problem (8L) (Solution)
Michael II
Post08-01-2003, 12:09    Subject: Audi A3 Door Auto Open/Close Problem (8L) Quote
The door automatically closes/opens immediately after being opened/closed.
Cause:
Due to unfavorable tolerances, the contact element of the microswitch slips out of its guide on the door locking cylinder, causing an unintended locking or unlocking action immediately after opening or closing.
The problem only occurs when using the door lock cylinder with the key profile; it does not occur when using the remote control.
Solution:
In case of a defect, replace the entire storage bracket, including the microswitch.
"Note:"
Applying a small amount of adhesive to bond the microswitch to the door locking cylinder has proven effective in minimizing tolerance-related movements. Loctite 480 is recommended as the adhesive.
Tschüss
Michael II
Translated on 06-08-2026, 15:07.
Ratings - Audi A3 Door Auto Open/Close Problem (8L)
No new posts Polo MJ 2002: Automatic Door Lock Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4 8D, production period up to 09/1999, cigarett... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L MJ 1999: Rattling/Humming Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Rear Door Won't Close? Fix It! Transmission, Chassis, Body & Interior
No new posts Automatic ZV Lock: Hands-Free Operation Transmission, Chassis, Body & Interior
No new posts Automatic Gearbox: Engine Changes Gears Itself Diesel Engine Technology
No new posts A6 Automatic Transmission Problems: Shifting Issues? On-Board Diagnostics (OBD)
