TT5 Shakes When LMM Removed
HHdieselpowerHH
Karma: +1 / -1   Thank you, like it!
Post29-08-2008, 15:03    Subject: TT5 Shakes When LMM Removed Quote
"Hi everyone, I'm having this strange problem where my car is making a humming noise. Yesterday, I unplugged the mass airflow sensor (MAF), and the engine runs better, but at the same time, the ESP and ABS lights come on. When I shift into reverse (R), it works normally, but when I shift into drive (D), the gear engages very abruptly, causing a lot of jerking – I thought the TT5 transmission might fly off. Why is it jerking, and why are the lights on? Is it the MAF sensor, the TT5 transmission, or the diesel pump that's faulty?"
I urgently need some tips.
Best regards, Harry.
AUDI A6 AVANT 2.5 TDI, 132 kW (179 hp), AKE (likely a specific equipment package), front scratches, automatic transmission (Tiptronic).
NAVI PLUS, CRUISE CONTROL, BOSE SOUND SYSTEM, SILVER METALLIC PAINT, ELECTRIC SEATS, etc.
Translated on 02-11-2026, 21:09.
mullemaus
Post29-08-2008, 21:00    Subject: TT5 Shakes When LMM Removed Quote
The V6 TDI absolutely requires the mass airflow sensor (MAF), otherwise the TT5 will be damaged!!! If you are not sure whether this part is defective, use the search function and perform a test drive according to the instructions. This should provide information. icon_wink.gif But if you care about your vehicle, do not drive it any further without fixing it! icon_wink.gif
Translated on 02-11-2026, 21:11.
HHdieselpowerHH
Post30-08-2008, 17:54    Subject: TT5 Shakes When LMM Removed Quote
"Hi, yes, it jerks when I unplug the connector, but otherwise it runs great. The problem is that when I unplug the connector from the mass airflow sensor (MAF), the engine sounds like it's getting more air. It also happens when I disconnect the hose from the EGR or the VTG, because when all of them are connected, the car makes a strange humming noise, as if it's not getting enough air. That's why I wanted to see what it's like to drive without the MAF sensor, because I've heard that some people drive with the connector unplugged, and I thought I'd try it. It jerked when I had the lever in 'D', so I quickly plugged the connector back in. Can you tell me something about that humming noise?"
Translated on 02-11-2026, 21:12.
bloesch
Post30-08-2008, 23:41    Subject: TT5 Shakes When LMM Removed Quote
Oh dear.
hey, i also don't use capitalization...
Sure, here's the translation:
"But please, use some punctuation marks occasionally, like periods, commas, or at least use paragraphs."
ARE YOU looking for help and expecting someone to struggle through THIS text?
no...
Translated on 02-11-2026, 21:13.
HHdieselpowerHH
Post31-08-2008, 18:32    Subject: TT5 Shakes When LMM Removed Quote
Sure.
Okay.
Do it.
I.
Translated on 02-11-2026, 21:14.
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia I 1999 - Front wipers only work when it's dry General Tips
No new posts TDI Engine Jerks at 2150-2200 RPM Diesel Engine Technology
No new posts 2.0 TDI Shakes: Common Rail Issues & Solutions Diesel Engine Technology
No new posts N75 Valve Hum When Engine Off? Diesel Engine Technology
No new posts Vibrating When Light Is On: Troubleshooting Guide Diesel Engine Technology
