"Chip tuning" only possible with the original tuner
CheBu
Post03-09-2008, 12:31    Subject: "Chip tuning" only possible with the original tuner Quote
Hello everyone,
I would like to "dechip" or at least slightly modify my AJM engine (manufactured in 1999) to reduce soot emissions. I've checked the usual suspects like the AGR valve, mass airflow sensor, and for any leaks, so I suspect the chip tuning is the cause.
Do I need to go directly to Digi-Tec to have this changed, or could an experienced mechanic with the appropriate VCDS knowledge reduce the fuel injection amount and turbo boost a bit?
Is there anyone here in this forum?
Thank you very much!
Stefan.
P.S.: It has a Digi-Tec chip that boosts the power to 140 horsepower with 340 Nm of torque.
Post03-09-2008, 18:10    Subject: Re: "Chip tuning" only possible with the original tuner Quote
CheBu wrote:
Do I need to go directly to Digi-Tec to have this changed, or can an experienced mechanic with the appropriate VCDS knowledge reduce the fuel injection amount and turbo boost a bit?
That's not possible with VCDS. For that, you need proper chip tuning equipment (both hardware and software).
However, anyone who has the necessary equipment and expertise can do it; that is, they can modify the software itself, rather than simply copying purchased tuning files into the customer's system.
Wiesel
Post03-09-2008, 19:05    Subject: "Chip tuning" only possible with the original tuner Quote
It could even become more complicated.
Digi-Tec occasionally uses copy protection sockets.
Then the only solution is to solder it.
Tribu
Karma: +3 / -2   Thank you, like it!
Post03-09-2008, 21:27    Subject: "Chip tuning" only possible with the original tuner Quote
Reduce the voltage of the control signal in ->Motor Electronics -> Channel 1.
Then it makes a little less noise. And finally, there's the turbo...
ReneASZFR
Avatar-ReneASZFR
Post03-09-2008, 21:39    Subject: "Chip tuning" only possible with the original tuner Quote
Hmm, I think I've seen this problem before.
Mine is also chipped by Digi-tech, and when you accelerate from the bottom end, it sounds like an old Russian steam locomotive.
In that case, they're really messing things up, to put it bluntly.
Post03-09-2008, 22:46    Subject: "Chip tuning" only possible with the original tuner Quote
Adjusting voltage for the AJM regulator?
There's nothing like it.
CheBu
Post04-09-2008, 7:26    Subject: "Chip tuning" only possible with the original tuner Quote
@ReneASZFRViewing profile: ReneASZFR: My chip is from the year 2000. I thought that they had already made some improvements there icon_sad.gif.
The chip was definitely removed and soldered in, but I don't know if Digi-Tec cleverly included a socket during the process...
However, with VCDS, it is possible to influence the fuel injection amount and turbo boost to a certain extent. There's also something called OBD tuning. Am I mistaken? Maybe that would be enough.
Thank you very much.
Stefan.
Post04-09-2008, 9:44    Subject: "Chip tuning" only possible with the original tuner Quote
CheBu wrote:
However, with VCDS, one can influence the injection quantity and turbo pressure to a certain extent.
For the VP-TDI, the injection quantity -> yes. In my experience, at least with my setup, channel 1 of the ASZ is not working = no effect.
The LD value cannot be changed on any TDI engine using VCDS.
There's also something called OBD tuning. Or am I wrong?
You are wrong, at least regarding changing the MSG dataset using VCDS -> it doesn't work because it's not a flashing tool.
Post04-09-2008, 10:12    Subject: "Chip tuning" only possible with the original tuner Quote
Nope, remove the ECU and solder it. -> It should be the person who installed it in the first place who does this, for warranty reasons.
CheBu
Post04-09-2008, 10:20    Subject: "Chip tuning" only possible with the original tuner Quote
Okay - I'm convinced. That's exactly why I wanted to avoid the long distances to Digi-Tec.
Thank you for the information!
Stefan.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log files related to the "thinking pause" issue when acce... Upload
No new posts Engine Misfire: Starting Issues & Troubleshooting Diesel Engine Technology
No new posts Snorkeling / "Kaudern": known. TDI AWX error? Diesel Engine Technology
No new posts ARL Turbo Lag: Causes and Solutions Diesel Engine Technology
