Stuttering During Regeneration: Which MWB Logs?
stolley
Karma: +38 / -1   Thank you, like it!
Post22-01-2014, 7:31    Subject: Stuttering During Regeneration: Which MWB Logs? Quote
Good morning!
My Polo 9N3 (1.4 TDI, 3-cylinder BWB, mileage: 214,000 km, with a recently refurbished cylinder head) has been shaking more noticeably lately during the DPF regeneration process.
Ich möchte während der Fahrt mal die interessanten MWB loggen. WWhat would those be?
And where can I find information about when the next regeneration is scheduled?
Thank you and best regards.
Volker.
Translated on 15-09-2026, 11:46.
Karma: +805 / -0   Thank you, like it!
Post22-01-2014, 10:32    Subject: Stuttering During Regeneration: Which MWB Logs? Quote
Please always include an Autoscan report with such questions, because otherwise you either have to guess or do extensive research to find out which control units are installed, instead of simply seeing them.
Translated on 15-09-2026, 11:47.
stolley
Post22-01-2014, 17:06    Subject: Stuttering During Regeneration: Which MWB Logs? Quote
dieselschrauber wrote:
Please always include an Autoscan report when asking questions, because otherwise you either have to guess or do extensive research to find out which control units are installed, instead of simply seeing them.
Best regards, Rainer
Oops, sorry!
Code:
Mittwoch,22,Januar,2014,17:03:08:25065
VCDS -- Windows-basierter VAG/VAS-Emulator
VCDS Version: 12.12.0.0
Datenstand: 20131116
Fahrzeug-Ident.-Nr.: WVWZZZ9NZ8Bxxxxxx   KFZ-Kennzeichen:
Kilometerstand: 214500km   Reparaturauftrag:
Fahrzeugtyp: 9N (9N - Polo())
Scan: 01 03 08 09 15 17 19 25 44 46 76
Fahrzeug-Ident.-Nr.: WVWZZZ9NZ8Bxxxxxx   Kilometerstand: 214500km
Adresse 01: Motorelektronik        Labeldatei: RKS\045-906-013-BMS.clb
   Teilenummer SW: 045 906 013 E    HW: 045 906 013 E
   Bauteil: R3 1,4L EDC G000SG  4271
   Revision: --H03---    Seriennummer: VWZ7Z0G5933092
   Codierung: 0003071
   Betriebsnr.: WSC 49000 143 80495
   VCID: 112F82EC0B0893960BD-513C
Readiness: 0 0 0 0 1
Adresse 03: Bremsenelektronik        Labeldatei: RKS\6R0-907-37x-ESP80.lbl
   Teilenummer SW: 6Q0 907 379 AS    HW: 6Q0 907 379 AS
   Bauteil: ESP 8.0 front   H05 0003
   Revision: 00000000    Seriennummer: 00000000000000
   Codierung: 0002365
   Betriebsnr.: WSC 00046 412 00000
   VCID: 8E1519909A360C6E96F-515A
Adresse 08: Klima-/Heizungsel.        Labeldatei: RKS\6Q0-820-045.lbl
   Teilenummer: 6Q0 820 045
   Bauteil: Klimaanlage        X0850
   VCID: EADD7500961E804EAA7-5178
Adresse 09: Zentralelektrik        Labeldatei: RKS\6Qx-937-049-C.lbl
   Teilenummer: 6Q1 937 049 F
   Bauteil: 0009 BN-SG.         2S36
   Codierung: 09646
   VCID: 3E7509503A165CEEA6F-515A
Adresse 15: Airbag        Labeldatei: RKS\6Q0-909-605-VW5.lbl
   Teilenummer: 1C0 909 605 K
   Bauteil: 19 AIRBAG VW51 0P   0010
   Codierung: 12601
   VCID: 2C513318DC6ADE7E18B-515A
Adresse 17: Schalttafeleinsatz        Labeldatei: RKS\6Q0-920-xxx-17.lbl
   Teilenummer: 6Q0 920 825 F
   Bauteil: KOMBIINSTRUMENT VDO V06
   Codierung: 01132
   Betriebsnr.: WSC 00000
   VCID: 377B1C74152C6DA6659-515A
Adresse 19: Diagnoseinterface        Labeldatei: RKS\6N0-909-901-19.lbl
   Teilenummer: 6N0 909 901
   Bauteil: 01K1 GATEWAY CAN    2S36
   Codierung: 00014
   VCID: F0E96768B0C27A9EE43-5178
Adresse 25: Wegfahrsperre        Labeldatei: RKS\5J0-920-xxx-25.clb
   Bauteil: IMMOBILIZER VDO V06
   Codierung: 01132
   VCID: 377B1C74152C6DA6659-5178
   WVWZZZ9NZ8B031810     VWZ7Z0G5933092
Adresse 44: Lenkhilfe        Labeldatei: RKS\6Q0-423-156.clb
   Teilenummer: 6Q0 423 156 AB
   Bauteil: LenkhilfeTRW        V270
   Codierung: 10110
   VCID: 6FEBE4142DFCE5667D9-5178
Adresse 46: Komfortsystem        Labeldatei: RKS\6Q0-959-433.lbl
   Teilenummer: 6Q0 959 433 E
   Bauteil: 3F Komfortgerát     0002
   Codierung: 00019
   VCID: 3D770E5C371047F6BF5-4B32
Adresse 76: Einparkhilfe        Labeldatei: RKS\7H0-919-283.lbl
   Teilenummer: 7H0 919 283 A
   Bauteil: Parkingsyst. 24 KUH 402
   Codierung: 00102
   VCID: 30692768F042BA9E243-5178
Ende   --------------------------------------------------------------------
Translated on 15-09-2026, 11:48.
Post22-01-2014, 18:25    Subject: Stuttering During Regeneration: Which MWB Logs? Quote
For those interested in the regeneration process itself, data blocks 67-70 are particularly relevant.
Jerking/Hesitation: Also, please also consider the engine mounts or the ash level in the DPF. At this mileage, the DPF should have already been replaced or cleaned.
If the "jerking" only occurs during regeneration, you can also log value 1 in measurement block 10. If there are "drops" in the values, the cause could be a clogged DPF, as this can sometimes trigger the turbocharger to pump in certain operating conditions.
Typically, this occurs at low engine speeds and low ambient air pressure, with a low air mass flow but a high boost pressure requirement.
See also:
Translated on 15-09-2026, 11:49.
stolley
Post22-01-2014, 20:52    Subject: Stuttering During Regeneration: Which MWB Logs? Quote
See also:
Hello Rainer,
Thank you for your feedback!
I would like to rule out engine mounts for now, as the jerking only occurs during regeneration.
And the DPF hasn't been replaced yet, I'm curious to see what the diagnostic readings say. However, I imagine that in my case, it's not yet at the point where it needs to be replaced, because I drive 55,000 km per year.
It could actually be something real... I think.
I will report!
Translated on 15-09-2026, 11:52.
stolley
Post18-03-2014, 7:55    Subject: Stuttering During Regeneration: Which MWB Logs? Quote
I have created the log and posted it under the link mentioned above.
Can you tell me something about the condition of the DPF, Rainer?
Volker
Translated on 15-09-2026, 11:54.
Post18-03-2014, 10:02    Subject: Stuttering During Regeneration: Which MWB Logs? Quote
up to 90 mbar differential pressure
Regarding the condition of the DPF, the following can be said:
- Either the 1.4 TDI received the same DPF (Diesel Particulate Filter) as the 1.9/2.0 TDI engines, which results in lower exhaust emissions and less ash buildup due to reduced oil/fuel consumption, thus explaining the low differential pressure.
- Or, the DPF (Diesel Particulate Filter) is not in perfect condition, meaning the ceramic component has cracks.
Whether it's the former or the latter, for the engine's perspective, there is no need for action regarding the DPF. If the rear is black, the latter is likely to be the case. icon_wink.gif
Consequently, if the rear of the unit is not black and all openings on the DPF are properly screwed/sealed, including the lines to the differential pressure sensor, then everything is fine with the DPF.
Only in the event that the ash mass exceeds the limit, should this value be moderately reset (halved), so that the engine control unit does not solely rely on the programmed ash mass to initiate regeneration cycles, which could then lead to a visit to the workshop.
Translated on 15-09-2026, 11:55.
stolley
Post19-03-2014, 7:05    Subject: Stuttering During Regeneration: Which MWB Logs? Quote
Hello Rainer,
Thank you for your assessment!
The rear is completely free of soot, which is a relief!
Best regards, Volker.
Translated on 15-09-2026, 11:57.
No new posts Windshield Wiper Regeneration General Tips
No new posts 1.6l CR-TDI, frequent regeneration / Diesel particulate f... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Gearbox: Won't Shift Gears While Driving Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Please log measurement blocks 008, 010, and 011 for the V... On-Board Diagnostics (OBD)
No new posts Tracking Channels: Which Ones to Log? On-Board Diagnostics (OBD)
No new posts Can VAG testers now log data series? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Engine Diagnostics: Read & Log Issues On-Board Diagnostics (OBD)
