Ski_Andi Blaumann
Joined: 01/09/2005 Posts: 48 Karma: +6 / -0 Location: Nürnberg
07-03-2009, 16:22 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
I downloaded the new VCDS update (the old version was from the beginning of 2008)).
The tool does not offer the extended measurement blocks for selection in the engine control unit.
In addition, the standard measurement blocks are completely different; even a scan up to 99 doesn't include things like boost pressure, etc.
Block 11 previously showed the boost pressure, but now it only displays the pressure.
Overall, the labels are not very self-explanatory.
Is this normal, or is it a problem with my computer?
Or can one obtain the old label files?
Greetings.
Andi.
A6 Avant 2,7tdi
ex:A4 Avant 81/105kW
vagtuning Guest
07-03-2009, 20:59 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
Could you please upload a car diagnostic scan of this vehicle?
Ski_Andi Blaumann
07-03-2009, 22:14 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
You mean the ECU scan,
or the scan from the engine control unit, up to channel 99?
A6 Avant 2,7tdi
vagtuning Guest
07-03-2009, 22:17 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
The former...
Ski_Andi Blaumann
07-03-2009, 23:21 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
Okay, I just finished the scan.
Okay, here's the translation:
"I've also attached a diagram of the control unit."
| Description: |
 Download |
| File name: |
blockmap-01-4F2-910-402-C 27tdi.xls |
| File size: |
26.5 KB |
| Downloaded: |
1093 times |
| Description: |
 Download |
| File name: |
Scann 4F Ski_Andi.txt |
| File size: |
1.37 KB |
| Downloaded: |
712 times |
A6 Avant 2,7tdi
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
08-03-2009, 0:03 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
Hello Andi,
You can either try to operate this tool with software from DRV,
what doesn't really work (-> download the corresponding version from Rainer's server).
or if your tool is from DRV, then support is only available from them.
Best regards, Micha.
vagtuning Guest
08-03-2009, 0:14 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
With Autoscan, it was about more than just the bill of materials.
(Right-click > save as)
Download it and copy it to the VCDS/Labels folder, overwriting any existing files if necessary.
In everything else, Wiesel is correct; theoretically, you are in the 'wrong' support forum http://www.ross-tech.com/vcds/download/labels/4F-01.lbl.
Ski_Andi Blaumann
08-03-2009, 12:13 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
Aha.
The connections weren't clear to me, Ross-Tech is the developer, and there are apparently two distributors in Germany?
I had asked a project team member to purchase a VAG-Com device, but unfortunately, he ended up researching and choosing a competitor's product instead.
Anyway, is the software the same, though?
Due to the list of prohibited items.
Yesterday, when I was selecting a vehicle in the menu, I didn't see the 4F option, and I also didn't immediately notice that there's an "Auto-detect" option in the selection list.
I have attached the scan.
The new label file is awesome. The data will be relabeled correctly, and the advanced measurement blocks will be selectable again.
You're very welcome!
Andi.
| Description: |
 Download |
| File name: |
Log-Ski_Andi.txt |
| File size: |
12.49 KB |
| Downloaded: |
2962 times |
A6 Avant 2,7tdi
Joined: 04/12/2002 Posts: 18134 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
08-03-2009, 12:28 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
Quote: | | Anyway, is the SW the same, though? |
No.
The main VCDS program is already quite comprehensive, but there are additional features and components available, some of which are included (here), while others are not (elsewhere). Keywords: KPower, KDataScope, etc.
Profile PM WWW Garage |
08-03-2009, 12:30 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
Hello Andi,
There are even more than two official distributors of VCDS in Germany.
Uwe Ross's English software runs on all distributions.
Ideally, the distributions are offered to each other as unregistered shareware.
Ski_Andi Blaumann
08-03-2009, 14:37 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
Do Rainer's plugins work with my version?
Then I would buy them too, I like them.
A6 Avant 2,7tdi
08-03-2009, 15:11 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
Depending on the interface (e.g., it works if it's an original interface from Uwe Ross), some...
Distributors can make the switch for a relatively small amount of money.
Just ask Rainer if it's possible with your IF (Intermittent Fasting) and what the cost would be.
The plugins would be included, if I recall correctly.
09-03-2009, 9:50 Subject: VCDS 805.2: Where is the Extended Measurement Channel Block? |
Quote: | | Do Rainer's plugins work with my version? |
Yes, running.
It is also possible to change the license, but in that case, the diagnostic cable must be sent in.
