Document A4 8D, production date up to 10/1999, dents on the D-pillar (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
CAN Support
Post08-01-2003, 15:53    Subject: Document A4 8D, production date up to 10/1999, dents on the D-pillar Quote
Dents or depressions on the outer surface of the D-pillar.
Cause:
Incorrectly set mixing parameters for the insulation foam in the D-pillar result in shrinkage of the insulation foam. The insulation foam, which is attached to the outer skin of the D-pillar, is integrated into the structure.
Solution:
Preheat the area to be bonded using a hot air gun (approximately 450°C outlet temperature) mounted on a D-pillar, keeping a distance of approximately 5 cm for 2-3 minutes. The indentations will naturally disappear due to the effect of heat.
Sure, here's the translation:
"Note:"
Choose a temperature that is not too high, as this could cause discoloration in the topcoat.
Tschüss
Michael II
Ratings - Document A4 8D, production date up to 10/1999, dents on the D-pillar
No new posts Doku Lupo 6X1 MJ 2002, Dellen im Dach Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis 06/2000, Knackgeräusche B-Säule Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L MJ 1999, Klappern / Brummen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wasser in A-Säule Audi100 C4 Transmission, Chassis, Body & Interior
No new posts Wie löst man die Scharnierschrauben an der A-Säule? Transmission, Chassis, Body & Interior
No new posts Golf 4 leckt an der A Säule (4 Türer) Transmission, Chassis, Body & Interior
No new posts What is the purpose of an ABE (General Operating Permit) ... Transmission, Chassis, Body & Interior
