Passat 3BG: Xenon Headlight Alignment Too Low
Go to page: 1, 2  Next
bindpe
Karma: +5 / -2   Thank you, like it!
Post03-09-2006, 22:02    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
Hello.
My friend is having the following problem with his Passat.
The xenon headlights are not adjusting properly and are therefore shining too low, illuminating a maximum of 10 meters in front of the car. I've already checked the FSP (Front Seat Position) using VAG Com, but there was no information stored.
Can you use the VAG-COM demo version to temporarily activate the software to check if the height adjustment function itself is still working? Or do you need the full version for that?
Thank you for your responses.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 30-08-2026, 3:03.
bloesch
Post03-09-2006, 22:18    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
Hi... that's easier to implement.
Car in front, turn on the lights... remember/mark the edge of the illuminated area.
Open the trunk, and one or two people sit on the edge of the trunk -> the LWR (license plate recognition system) must adjust!
However, if there is an error in the LWE (Linear Watermarking), it should be recorded in the error log.
Have you ever tried properly adjusting them (with the default settings)?
Translated on 30-08-2026, 3:04.
bindpe
Post03-09-2006, 22:22    Subject: SEO-Optimized Website Design: Tips & Tricks Quote
Hello, Smurfette.
I've already tried the trick with the wall, but nothing happens.
As I said, no filler in the FSP.
How does that relate to the default settings?
Spritmonitor.de
Translated on 30-08-2026, 3:05.
bloesch
Post03-09-2006, 23:04    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
As I said, no errors in the FSP
Strange...
default setting:
(original VAG tester... I have no experience with VAG-COM).
stg f headlight range adjustment, ADR 55.
Then, set the default to 04.
then 001... wait... set SW.
then 002 for saving.
Translated on 30-08-2026, 3:06.
pax
Avatar-pax
2000 Volkswagen Passat
Post04-09-2006, 15:50    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
For the basic setting: http://www.ross-tech.com/vag-com/cars/xenonalignment.html
Somewhere, they were also checking whether the sensor readings were accurate and whether they changed when the car was shaken.
Bye.
peace
Translated on 30-08-2026, 3:07.
bindpe
Post04-09-2006, 17:54    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
Hello.
Thank you for the answers. Can I also perform the basic settings with a shareware license from VAG-COM?
Spritmonitor.de
Translated on 30-08-2026, 3:08.
R.M.
Karma: +14 / -0   Thank you, like it!
Post15-10-2006, 17:47    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
I'd like to bring up this topic again, as it seems I'm experiencing the exact same problem.
I installed an aLWR system in my Passat (AFN, 1998). When exactly does it activate? It's clear when the lights are turned on. But does it activate when the car is stationary? Or does the car have to be moving? Is there a delay?
"In any case, the fault memory is clear, the basic settings have been applied, and the sensor values are okay (they also fluctuate as expected when you move the car around). Actuator diagnostics are possible. Nevertheless, the lights don't dim when I load the trunk. The only thing I haven't checked yet is whether the aLWR control unit also receives the speed signal. Suddenly, there was no power in the laptop. However, the Gala signal probably doesn't play a role if the aLWR is already adjusting when the car is stationary."
Does anyone have any more suggestions or tips for me?
Translated on 30-08-2026, 3:09.
Post15-10-2006, 18:37    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
I can only tell you that, for example, in the Golf Mk2 and all other models up to that point, the headlight alignment is only adjusted once: when you turn on the lights, the system compares the vehicle's position at that moment using a sensor located on the front left side of the axle.
Paleolithic xenon.
I don't know what condition your Passat is in now, but I suspect that dynamic headlight range control was introduced with the 3BG model, along with the introduction of Bi-Xenon headlights. Is your car a 1998 model, which would be a 3B? If so, it likely has the same type of Xenon headlights as my Golf: a small lens, static headlight range control, and Mono-Xenon.
Translated on 30-08-2026, 3:11.
R.M.
Post15-10-2006, 19:18    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
When you turn on the light, it compares the vehicle's position at that moment using the sensor located on the front left side of the axle.
Front or rear? Only with the Porsche, right? I load my Passat in the back. But what's the point of all this effort? So why have a sensor on the front axle if the lights don't dim when accelerating, i.e., when the front of the car lifts? A sensor on the rear axle would be enough for just the loading state.
"But then maybe I can check it. I'll get in the trunk and then, using a really long arm, turn on the light. Then something should happen up front..."
Thank you for the tip!
Best regards!
Translated on 30-08-2026, 3:13.
R.M.
Post15-10-2006, 20:02    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
That's already helpful. Thank you! At least now I know exactly what I'm dealing with. I'm only interested in the distance at which the static aLWR system adjusts.
I had also searched the web, but only found information like "Help, I can't register my Chinese-e*ay burners" in various dubious forums, which weren't really helpful.
Best regards!
Translated on 30-08-2026, 3:14.
Post15-10-2006, 20:31    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
Well... the location for installation is basically irrelevant, because the front of the car rises in proportion to how much the rear drops. Besides, a shorter cable saves money.
"Static" means that nothing is adjusted automatically; instead, it's like with a light meter in the cockpit, where the exposure is set based on the current lighting conditions and the subject's brightness.
As previously mentioned: Stone Age Xenon.
Translated on 30-08-2026, 3:15.
pax
Avatar-pax
Post15-10-2006, 20:47    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
The front of the car also rises in proportion to how much the rear drops.
Are you sure about that? I can imagine that if you load weight behind the rear axle, but what if, for example, three people are sitting on the back seat, either in front of or on top of the rear axle? How does that affect it?
Bye.
peace
Translated on 30-08-2026, 3:16.
Post15-10-2006, 21:16    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
As I said, it needs to move in relation to each other, because otherwise you won't be able to blind anyone, since the car doesn't bend in the middle icon_smile.gif.
Installation location for Golf: Front axle... they didn't install it there because it wouldn't make sense.
Translated on 30-08-2026, 3:17.
R.M.
Post15-10-2006, 21:21    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
Front AND rear axle.
Of course, you can blind someone without adjusting the front axle if you have a load in the back. This happens when the front axle is the pivot point, like on a seesaw.
Best regards!
Gelegenheitsschrauber
Audi A4 likes this.
Post16-10-2006, 9:21    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
R.M. wrote:
Of course, you can blind someone without adjusting the front axle if you are carrying a load in the back. This happens when the front axle is the pivot point, like on a seesaw...
Right. And that's the case when the weight is *exactly* on the rear axle!
Greetings,
Frank.
99er G4 GTI AHF mit Kaufmann Stufe 1-Tuning, 173.000 km
//images.spritmonitor.de/178723_5.png
Translated on 30-08-2026, 3:18.
R.M.
Post16-10-2006, 18:04    Subject: Passat 3BG: Xenon Headlight Alignment Too Low Quote
But why have a sensor in the front, if lifting of the front of the vehicle (which only happens dynamically during acceleration) is not taken into account anyway? Surely one sensor in the rear is sufficient for the general loading state. icon_question.gif
It essentially depends only on whether the load is placed in front of or behind the rear axle (passengers or luggage), which determines the exact location of the center of gravity.
Of course, a real dynamic regulation wouldn't be possible with the old actuators anyway, they are far too slow for that. But at least a regular adjustment would be okay, which they are supposedly supposed to do. It would be interesting to know, if I turn on the light and then get into the trunk next to the box of beer, how long it takes before the sensors are queried again and the system is adjusted. icon_question.gif
There are more unpleasant homework assignments...
Best regards!
Translated on 30-08-2026, 3:19.
No new posts Doku Golf 1J bis 06/99, Scheibenwaschdüsen spritzen zu tief Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low beam, high beam, and headlight flash with xenon in th... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Xenon Scheinwerfer On-Board Diagnostics (OBD)
No new posts Headlight Failure Monitoring FIS A3 8P On-Board Diagnostics (OBD)
No new posts 3C Xenon KurvenLicht Upload
