Lift for VW Golf 4
Avenga
Post09-10-2008, 12:21    Subject: Lift for VW Golf 4 Quote
I need to quickly find out where to position the lift arms on a Volkswagen Golf 4. Unfortunately, there's no manual included with the vehicle (as there usually is). I need to do the exhaust work tomorrow.
I noticed a large bulge under the driver's side door, near where the jack is usually placed. It looks like someone has definitely been messing around with that area before.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post09-10-2008, 12:56    Subject: Lift for VW Golf 4 Quote
Okay, at the designated points on the front and rear sills (near the wheels), where the jack also attaches - read the owner's manual icon_rolleyes.gif.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Post09-10-2008, 13:32    Subject: Lift for VW Golf 4 Quote
Well, if he doesn't have a logbook...
So, I'm going to wash the Golf, and then I'll see some embedded markings in the shape of a triangle on the rocker panel. They specify the height, and then the lifting platform is positioned at that height on the pier.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post09-10-2008, 14:11    Subject: Lift for VW Golf 4 Quote
It also works at the indicated point; you just need to place the 1-meter long piece of wood ("Dielstück") on the plate, which will distribute the lifting force without pressing down on the sill.
Avenga
Post09-10-2008, 17:40    Subject: Lift for VW Golf 4 Quote
Okay, so it's the standard way on the sill of the car, near the rear wheel arch. On the Seat Ibiza, there's a specifically designed metal attachment point in the back for the lifting platform (not a jack).
Okay, then I'll check the markings.
Post09-10-2008, 20:13    Subject: Lift for VW Golf 4 Quote
Down there, there should be a lot of metal anyway, and it's certainly a given that a car lift or lifting platform should never have plastic panels.
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lift Test: Drive Mode & Functionality Check Transmission, Chassis, Body & Interior
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
